skybren Posted November 3, 2007 Share Posted November 3, 2007 I have alway owned Loyales. I just obtained a 1994 legacy. I changed the oil and noticed alot of oil on the bottom of the engine. I am not sure but I think the engine is a 2.2. Are there any quirks to these engines about oil leaks. The first thing I will do is replace vavle cover gaskets, any other suggestions. Also what years of Leagacy's are the parts interchangeable, again I have not owned a Legacy before, thanks in advance Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 3, 2007 Share Posted November 3, 2007 Hi skybren. Yes I have a '94 Legacy too! These 2.2L's, with mileage/age, have a number of possible engine oil leak points front cam seals front crank seal - can also be oil pump rotor cover screws backing out and directing some oil out the front crank seal LH cam front support o-ring If you see the bottom of the timing belt covers a bit 'wet' with oil, there is most likely a leak in the above mentioned areas rear main seal valve covers RH cam rear support o-ring I have some pics of these various items if needed. Quote Link to comment Share on other sites More sharing options...
ericem Posted November 3, 2007 Share Posted November 3, 2007 Also verify its not a rack and pinion leak. My car has on the bottom is drenched in oil in various places yet I do not notice much oil loss. Quote Link to comment Share on other sites More sharing options...
rweddy Posted November 3, 2007 Share Posted November 3, 2007 I have alway owned Loyales. I just obtained a 1994 legacy. I changed the oil and noticed alot of oil on the bottom of the engine.I am not sure but I think the engine is a 2.2. Are there any quirks to these engines about oil leaks. The first thing I will do is replace vavle cover gaskets, any other suggestions. Also what years of Leagacy's are the parts interchangeable, again I have not owned a Legacy before, thanks in advance Probalby oil pump screws or crank seal. When was the last timing belt done? Quote Link to comment Share on other sites More sharing options...
