rdavis434 Posted November 4, 2007 Share Posted November 4, 2007 Help!!! I have a 91 Legacy that has no spark. I have tested the coil, ignition control unit and the main computer. All of the parts worked in another Subaru. I have also tested the gas line for pressure and it will pump gas. I have know idea what I need to look at next. Any ideas? Thanks. Link to comment Share on other sites More sharing options...
lmdew Posted November 4, 2007 Share Posted November 4, 2007 Check the Crank and Cam Sensors. You should have a CEL light on if these are out, but you never know. The Crank Sensor triggers the spark I believe. Link to comment Share on other sites More sharing options...
Cougar Posted November 4, 2007 Share Posted November 4, 2007 Have you checked for power getting to the ignition system? If not, do that. Link to comment Share on other sites More sharing options...
rdavis434 Posted November 4, 2007 Author Share Posted November 4, 2007 Cougar said: Have you checked for power getting to the ignition system? If not, do that. And how do I go about that? That seems to be the problem. The car isn't sparking. It will turn over and over but no spark. All the fuses are good and the fusable link is good. As I stated in the lead string I have checked the coil, ignightor, computer, and fuel pump. What else is there? Link to comment Share on other sites More sharing options...
rdavis434 Posted November 4, 2007 Author Share Posted November 4, 2007 lmdew said: Check the Crank and Cam Sensors. You should have a CEL light on if these are out, but you never know. The Crank Sensor triggers the spark I believe. I did change that out and that didn't work but it was a used part. So I guess I will go back and revisit it and verify it in another Legacy. Thanks. I will let you know. Any other ideas on top of that?? Link to comment Share on other sites More sharing options...
Cougar Posted November 4, 2007 Share Posted November 4, 2007 I think a common problem for the ignition power was a faulty connector terminal that tied to the ignition switch. The connector was under the steering column. You would need to remove the cover under it to get at it. To check for power you need to use either a test light probe or a voltmeter. You need to verify that power is getting to the ignition using one of these testers at least. You can't just look at it and assume it is ok. Link to comment Share on other sites More sharing options...
rdavis434 Posted November 4, 2007 Author Share Posted November 4, 2007 Cougar said: I think a common problem for the ignition power was a faulty connector terminal that tied to the ignition switch. The connector was under the steering column. You would need to remove the cover under it to get at it. To check for power you need to use either a test light probe or a voltmeter. You need to verify that power is getting to the ignition using one of these testers at least. You can't just look at it and assume it is ok. Do you know the name of that part and or what it looks like? Would the ignition plug into it? Link to comment Share on other sites More sharing options...
Cougar Posted November 5, 2007 Share Posted November 5, 2007 Check for power getting to the coil and ignition module that you tested already in another vehicle. Do not test the high voltage leads for voltage even if the ignition isn't working. Link to comment Share on other sites More sharing options...
porcupine73 Posted November 5, 2007 Share Posted November 5, 2007 Are you sure the timing belt has not broken? Link to comment Share on other sites More sharing options...
rdavis434 Posted November 5, 2007 Author Share Posted November 5, 2007 porcupine73 said: Are you sure the timing belt has not broken? ummm yup. know that. Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 5, 2007 Share Posted November 5, 2007 rdavis434 said: ummm yup. know that. Seriously...... You need to start by confirming that there is power at the ignition switch by testing the power lead into the ignition switch for voltage . Use a test light. If there is power then test the power wire coming out from the ignition switch with the key in the on position and check that for power. Once you have verified power in both positions then you can move forward to the engine bay for faults w/no spark. You really need to do things in order to slowly ween out the possibilities. Let us know. Link to comment Share on other sites More sharing options...
