Numbchux Posted November 5, 2007 Share Posted November 5, 2007 so, some of you may have seen the '86 GL Wagon I had listed in the FS section. well, dhise has claimed it, and hopefully over the next month, I'll be working out the gremlins, and turning it from a POS into a sweet car. well, went to pick it up, and as I was leaving to drive it home, the HH cable (which I didn't know wasn't hooked up) meandered it's way over to the + battery cable.....and did this: yikes, minor setback. well, I've got another battery.....as I'm driving up here into Duluth, I'm coasting down the big hill into town, and look down and see this: stupid vacuum leaks....darn engine won't stay running. that's ok....it's all coming out anyway. I had it idling (@ about 400 rpms) in my driveway today....and though, boy, that things spinning so slow, I could stop that clutch fan. so I used a stick to stop it, and took this: got a few dents, but nothing serious: not really scratched at all, so I think those should pop right out. if not....I've got more body panels from my '85. mmmm.....peeling clear coat. I think it was overheated bigtime (which would explain why it had a burned valve when my buddy bought it a couple years ago), and the overflow tank boiled over.... but nothing a little sandpaper and an afternoon with an HVLP gun can't fix. Link to comment Share on other sites More sharing options...
Numbchux Posted November 5, 2007 Author Share Posted November 5, 2007 plans/checklist x '96 EJ22e from an impreza (that's getting an '05 WRX drivetrain/dash). timing belt/water pump/main seals x radiator x clutch bumpers corner markers passenger side door mirror (you may notice in the pics....it's held on with silicone) x rear discs front brake pads wheel bearing seals fix the surface rust on the hatch fixed body panels (one x = I have the parts. 2 = installed.) and......GO Link to comment Share on other sites More sharing options...
dhise Posted November 6, 2007 Share Posted November 6, 2007 no need to go crazy on the hatch and clear coat, I've become pretty good at taking care of those things... Any dent pounding is much appreciated though! Also, there is this aftermarket belt/seal/h2o pump on ebay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=013&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=230187975664&rd=1 Judging by some other threads on these kits they may not be a bad option, what do you think? -Doug Link to comment Share on other sites More sharing options...
Numbchux Posted November 6, 2007 Author Share Posted November 6, 2007 dhise said: no need to go crazy on the hatch and clear coat, I've become pretty good at taking care of those things... Any dent pounding is much appreciated though! Also, there is this aftermarket belt/seal/h2o pump on ebay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=013&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=230187975664&rd=1 Judging by some other threads on these kits they may not be a bad option, what do you think? -Doug I love PCI timing kits. had 3 of them on various cars. but I may just get the timing kit, and get the water pump and seals via my connection at the local subaru dealer. might save some money. Link to comment Share on other sites More sharing options...
Subarutex Posted November 6, 2007 Share Posted November 6, 2007 FYI... i've bought from "The Import Experts" plenty of times off ebay. They deliver a very quality product and decent prices... and have excellent shipping and communication skills! Link to comment Share on other sites More sharing options...
Phizinza Posted November 7, 2007 Share Posted November 7, 2007 Numbchux said: Man does that bring back REALLY bad memories... Link to comment Share on other sites More sharing options...
Numbchux Posted November 14, 2007 Author Share Posted November 14, 2007 hmmmm: Link to comment Share on other sites More sharing options...
Numbchux Posted November 15, 2007 Author Share Posted November 15, 2007 wiring! still more work to do, but I moved the 2 plugs on the engine harness closer to the ECU plug, and then stripped the bulkhead harness down to just the necessities. I'll be shortening all those wires to the relays and such, and installing in the car before the swap. so when the time comes (I only have the garage for the weekend...and I'd like to do it all in a day), I can string it all through the firewall, plug it in, and be ready to rock. Link to comment Share on other sites More sharing options...
dhise Posted November 15, 2007 Share Posted November 15, 2007 Appreciate all the pics and updates! A question: with an OBDII computer is there still going to be a plug to connect a code scanning tool with this conversion? -Doug Link to comment Share on other sites More sharing options...
Numbchux Posted November 16, 2007 Author Share Posted November 16, 2007 dhise said: Appreciate all the pics and updates! A question: with an OBDII computer is there still going to be a plug to connect a code scanning tool with this conversion? -Doug yep, the diagnostic port was retained in the harness modification. Link to comment Share on other sites More sharing options...
