tuner-automotive Posted November 6, 2007 Share Posted November 6, 2007 2.2l 96 outback 5MT. The gear shift lever feels like its in the wrong spot? Usually you would pull the gear shift lever towards you and then up for 1st gear and straight up from neutral for 3rd gear. My shift lever doesnt allow me to go towards me and up it just barely moves towards the driver seat and up. And 3rd gear doesnt go straight up but kinda towards the passenger seat and then up. I think something is missaligned ? I can drive the car no problem but Im also trying to tackle a vibration/rattle noise down aswell and the sound seems to be coming from between the frt seats below the middle console. I think the 2 issues are combines someway? Bad Tranny mounts or engine mounts cause this issue??? Link to comment Share on other sites More sharing options...
nipper Posted November 6, 2007 Share Posted November 6, 2007 bad tranny mounts longshot, but more likely tired bushings in the shift linkage. Get under the car and have seomone operate the shifter and watch all the parts. Look for play. The source will be obvious. nipper Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 6, 2007 Author Share Posted November 6, 2007 Any way to check this by myself? Im all alone here.:-\ Link to comment Share on other sites More sharing options...
nipper Posted November 6, 2007 Share Posted November 6, 2007 Just get under ther car and shakes things. nipper Link to comment Share on other sites More sharing options...
Towel Rail Posted November 6, 2007 Share Posted November 6, 2007 Salem, Oregon must be even smaller than I imagined! My car (which also features a sloppy shifter) shifts the same way, more like a 'W' pattern than an 'H'. Both 3rd and 4th are further to the right than I would expect them, but I've adapted. We'll see if replacing the shifter bushings helps... - Scott Link to comment Share on other sites More sharing options...
jamal Posted November 6, 2007 Share Posted November 6, 2007 get a new center return spring. Link to comment Share on other sites More sharing options...
