rruge Posted November 6, 2007 Share Posted November 6, 2007 Hi Guys, I hope everyone is well. I am looking at my 1996 Outback Wagon, automatic, 2.5L. I just got an OBDII scan tool that is showing an MAF reading of zero. However, no trouble code is registering in the car's computer; i.e. my MIL/check engine light is off. There is not a lot of troubleshooting data in the Haynes manual: 4 to 7 grams/second under idle is the expected range. I would like to make sure the wiring is OK. I already checked for +12VDC on one of the pins. Would I get a trouble code if the wiring was not OK? Is there anything I could do to the sensor aside from beating it to get it working? Does it come apart? If it is bad, is my only choice to replace it? I read in one of the posts that someone replaced only a $55 "reed". I haven't seen that part online yet. There isn't terrible performance but I would like to know that I am getting optimal fuel mileage for my car. Any and all responses are appreciated. Take care. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 7, 2007 Share Posted November 7, 2007 I would suspect your scan tool is not reporting the value. If you were really getting a reading of zero I would imagine you would have a CEL/MIL. Quote Link to comment Share on other sites More sharing options...
Manarius Posted November 7, 2007 Share Posted November 7, 2007 I would suspect your scan tool is not reporting the value. If you were really getting a reading of zero I would imagine you would have a CEL/MIL.If you got a reading of 0, your car would run like crap. You would be getting the car fixed with haste. Quote Link to comment Share on other sites More sharing options...
