obskermit Posted November 7, 2007 Share Posted November 7, 2007 I just broke 100K in my 2000 Outback Sport. 2.2L Manual. Still running strong. It consumes quite a bit of oil though. It just magically disappears. There are no drips in my drive way, and the exhaust vapor is pretty clear so it doesn’t appear to be burning it too significantly. ???? If I don’t add any by the end of 3k miles it isn’t even on the dip stick. Any suggestions? Lastly, I know I have a timing belt replacement due at 105K... and I’ll do the water pump at that time too. Anything else I should do at that point? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 7, 2007 Share Posted November 7, 2007 Hi obskermit and congrats! A common thing to check for mysterious oil consumption is PCV valve. For the timing belt and water pump, also replace the geared/toothed timing belt idler near the water pump. At least inspect the other idlers and tensioner for wear/freeplay/etc for possible replacement. Front crank seal on oil pump, front cam seals, cam cap o-rings (assuming that year 2.2L still has them). Possibly reseal oil pump and replace discharge o-ring and while pump is out check rear case cover screws for backing out (was more a problem on earlier engines) and loctite them in. Quote Link to comment Share on other sites More sharing options...
Towel Rail Posted November 7, 2007 Share Posted November 7, 2007 Congrats! It's almost broken in! Quote Link to comment Share on other sites More sharing options...
obskermit Posted November 7, 2007 Author Share Posted November 7, 2007 Hi obskermit and congrats! A common thing to check for mysterious oil consumption is PCV valve. Sounds good.... Now how do i know if its bad? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 7, 2007 Share Posted November 7, 2007 Well if you've never replaced it just put on a new oem one; they're about $7. People tell me if you remove the old one and it rattles, it should be good. If it's all gunked up in there you can either replace it or some people try to clean them out. I believe on my soobs it takes a 22mm or if not available a 7/8" wrench to get it out. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 7, 2007 Share Posted November 7, 2007 Prolly a good idea to replace them on my 2 Subies. Where is it located on the 2.5 gen 1 motor? Thanks for any help! Quote Link to comment Share on other sites More sharing options...
obskermit Posted November 7, 2007 Author Share Posted November 7, 2007 Prolly a good idea to replace them on my 2 Subies. Where is it located on the 2.5 gen 1 motor? Thanks for any help! X2 - Where will I find this? I looked on line at Advance Auto and found them for about $4 i'll probably pick on up on the way home. Will i need any new hoses, or is it easier to remove then that stupid fuel filter! Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 7, 2007 Share Posted November 7, 2007 The PCV valve is typically on the intake manifold right near the throttle body. As with most parts you are generally better off paying the extra couple dollars and getting the Subaru OEM part. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 7, 2007 Share Posted November 7, 2007 Quote Link to comment Share on other sites More sharing options...
obskermit Posted November 8, 2007 Author Share Posted November 8, 2007 THANKS! thanks for the photo. that realy clears thigs up. usually i just buy the part first and then look at the engine to see what it looks like. ha ha. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 8, 2007 Share Posted November 8, 2007 Yea, I too have also bought a part, but don't know exactly where to find its location on the motor. Thanks for the great picture pointing out the location of the PCV valve. You are a big help. Quote Link to comment Share on other sites More sharing options...
obskermit Posted November 14, 2007 Author Share Posted November 14, 2007 Well i changed the PCV valve and fuel filter. The PCV was all rusty and gummy so im sure it needed to be changed. From there i noticed an immediate improvement in idle (wasnt bad before but now its very smooth) and it feels a little peppier. We will see in a few weeks if it fixed the oil consumption problem. Thanks for the advice.. Quote Link to comment Share on other sites More sharing options...
