high mileage gas mileage....??
Driving style is a big factor.
I found the temp sensor on my 93 Impreza was a factor even though the sensor didn't throw a code.
What about carbon build up on the intake valves? Maybe a throttle stomp with every tank full will blow some carbon out. Isn't this carbon build up a common problem?
I also recommend Lubrilon engine treatment. http://www.xcelplus.com/products.htm
I think it is good for older high mileage engines.
I have used it in 2 cars now with good improvement in mpg.
Take care,
John
No I have no idea. How would I find out?
On level ground on the highway, are the RPMS always "normal"? If they run higher or occasionally shoot up for no apparent reason on level ground, there's a problem. It's the auto version of a slipping clutch, sort of, though I don't think it's common at all.
  • 3 years later...
