how to seat your torque converter , by mnwolftrack
how to seat your torque converter , by mnwolftrack (copied from http://www.ultimatesubaru.org/forum/showpost.php?p=672461&postcount=64 )
First Photo:
Here's a picture of the first stopping point when sliding the torque converter into the transmission (assuming it had been completely removed). The first stopping point can vary a little bit, so don't be too concerned if yours stops in a slightly different spot. Note that I drew a black marker line on the torque converter flange where the mounting bolts go. This line represents what would be the "fully seated" position of the flange when comparing the flange to the front mounting surface of the transmission when looking square at the side of the transmission (e.g. front mounting surface of transmission is perfectly in line with your line of site).
As this picture shows, the torque converter is not fully seated yet, as shown by the black line (straight up and down) on the flange which is roughly an inch away from the front mounting surface of the transmission:
Second Photo:
From here, I make a "fishhook" with my pointer finger on one hand and suspend the tip of the torque converter in the "hook" to hold it's weight as if it were fully seated. This helps prevent the torque converter from binding when trying to seat it (makes seating easier). Then, I spin the torque converter clockwise a few times and then counter clock wise a few times to see if it will catch to get to the second stopping point (if a few spins don't do it, I do a few more. If it's still a no go, I pull the torque converter back out and put it back in in a different position). Here's a picture of the second stopping point (easiliy confused for fully seated), in which the black marker line is still about 1/4-1/2 inch away from being flush with mounting flange:
If you think the torque converter is fully seated (above photo) at the second stopping point, it's NOT! It needs to go another 1/4 to 1/2 inch.
Third Photo:
To get the torque converter to fully seat, I spin in the opposite direction that just did that got it to seat in the 2nd stopping point. Then, when fully seated, it will look like this:
Forth Photo:
Another angle of it fully seated, line of site no longer flush with transmission mounting surface, and you can see the black marker line a little better:
Fifth Photo:
Yet another angle, fully seated:
Heres' my pics.
This one shows the ring seal that slipped out of the groove on the TC shaft and prevented complete insertion of the TC pas that last .25 inch. I recommend getting a new part, since the old one gets floppy and slips out of the groove.ring_seal_Placed2_2_.jpg
Thi sis the new part in a bag with number:
This is the correct placement of the TC looking at the bottom:
You can see how it matches the cutaways.
  • 4 months later...
  • 1 year later...
bump for newbies.
howtoseattorqueconverter
torqueconverter
seatingtorqueconverter
^^If this is a link, its not working. Neither is the green color, can barley see it.
  john in KY said:
Only one: shaft presses against the internal oil pump and destroys it. No pump=no ATF circulating=no movement. Been there, done that.
Ditto :-\
Again, here's my pics.
picture.php?albumid=120&pictureid=979
This is the new part in a bag with number:
picture.php?albumid=120&pictureid=977
picture.php?albumid=120&pictureid=978
  • 9 months later...
this thread loses a lot of it's effectiveness without the pics in the first post, too bad.
mnwolftrack hasn't been on the board since 2008. if anyone happens to know him, how about telling him we need his torque converter pics.
they were great pics.
Edited by johnceggleston
  • 9 months later...
the original pics are gone so i have added some that i took today. not perfect pics but better than none. if i get better ones while i can still edit i will add them.
torque converter not seated.
Below is a picture of the first stopping point when sliding the torque converter into the transmission (assuming it had been completely removed). The first stopping point can vary a little bit, so don't be too concerned if yours stops in a slightly different spot.
As this picture shows, the torque converter is not fully seated yet, the flange which is roughly an inch away from the front mounting surface of the transmission:
From here, I make a "fishhook" with my pointer finger on one hand and suspend the tip of the torque converter in the "hook" to hold it's weight as if it were fully seated. This helps prevent the torque converter from binding when trying to seat it (makes seating easier). Then, I spin the torque converter clockwise a few times and then counter clock wise a few times to see if it will catch to get to the second stopping point (if a few spins don't do it, I do a few more. If it's still a no go, I pull the torque converter back out and put it back in in a different position). Here's a picture of the second stopping point (easliy confused for fully seated) :
second stop pic below:
To get the torque converter to fully seat, I spin in the opposite direction that just did that got it to seat in the 2nd stopping point. Then, when fully seated, it will look like this: (notice how close the face of the flange is compared to the engine mating face of the trans.)
tagline: ''seat torqueconverter''
  • 4 weeks later...
A million thank you's for this! I was stuck at the 2nd stopping point for 2 days! Read through this, pulled it off, tried again, and boom, it clunked into place, all 3 times. I put a zip-tie (the kind used for mounting oil coolers or electric fans to a radiator) through one of the mounting holes, and out through a hole on the back of the bellhousing.
One thing to note is that some of the newer stuff has a "clip" of sorts on the oil pump drive shaft that has to seat into one of the two drive slots on the TC... it only fits properly into ONE of them and not the other. This means that if the TC has come out of the tranny you need to first fish out the oil pump drive shaft and seat it onto the TC and then install both of them as an assembly. Why they have this extra clip I do not know - but it's there any should be checked for if you have something from the later 90's and beyond. I just encountered this on a '99 Forester with a factory rebuilt tranny in it.
I always tell people they know the TQ is seated when the distance from the mounting ears to the tranny bell housing is LESS than the distance of the mounting holes in the flex plate to the engine bell housing.
I would advise not to remove the torque converter if it is not necessary, other than a bad seal or disassembly of the trans. It would be the preferred method to leave the torque converter with the trans when pulling an engine for other services.
  • 6 months later...
  mercuryrising17 said:
I have an 02 legacy and the tx slipped out just a little when removing the engine. I was able to slip it right back into place and when I manually turn the tx I can hear fluid slushing around. Am I safe to assume that everything is in place and I can bolt the engine back on?
As I said further back:
Since the tq is half full of fluid, yes, it'll slosh a bit. That's normal. If it turns freely and passes the above check, you should be fine.
  • 3 months later...
Having just done this for the first time, if you follow the steps outlined in this thread, you should have no trouble. First timer, done in 3 minutes. Here's another way to see that it's in place. Look at the torque converter through the hole in the bell housing for the starter. There should be less than 1/8 of an inch between torque converter and the bell housing.
Here's a shot for a little extra help. This is a 2000 Outback. The rim of the torque converter was just under 3/16 of an inch from the bell housing.
Edited by AdventureSubaru
That wasn't bad at all. The thing i think of when poking a TC is that the TQ always has to move towards the flex plate. So if I'm unsure of the depth, I measure and make sure that the TC will have room to move towards the Flex plate. If you bolt up the trans/engine so the TC doesn't move back and forth and is pressed hard against the flex plate, it's not poked all the way.
I was a bit sceered of this one, but it turned out to be the fastest I have ever done. I literally spent more time skimming this thread than poking the TC.
