Lights, Camera...
Hey No LIGHTS!!!
I just realized that I have no Lights behind my Heater/AC & my Shift Lever. Fuses look good under hood & dash. Any ideas? I DO need to replace the Flasher Module. I doubt it's related, but who knows...
Thanks
Fat Tony
Super common for the bulbs to blow out on the AC controls. You can pull the assembly and replace the bulbs pretty easily. Search and you can find info on that. As for the shifter it's probably just a bulb or two as well. I don't have much experiance with anything relating to automatics.
Keith
Yea, I have the same problem with some of the lights burned out on the climate controls. I read about how to take apart to fix, but it seemed like more throuble then it is worth, so I live with only partial lighting.
Regarding the back lighting on the auto trany shifter, I replaced the bulb on a 91 Legacy years back. I made a mess of some of the plastic cover work around the shift lever, as some small pieces of plastic split and broke off. Everything went back together pretty well, and cosmetically looked okay, but I wasn't proud of my work cracking the plastic cover.
I just replaced all three bulbs in the HVAC panel in my 1998 Legacy L. Just follow the instructions in the links in the previous post. It is quite straightforward. I did it in less than an hour, working slowly.
The Radio Shack bulbs work just fine. I did make them "longer" to match the old bulbs by using a small length of the empty end of the plastic ink tube from a cheap ball point pen. One tip I can add is that after you have them in the Subaru holders, test them with a 9 volt battery before you trim the wire leads. It's nice to be confident they work before you put them in.
Thanks for all the responses! I'll Tinker with this problem this weekend. After I put my SNOW TIRES ON! It's starting to come down here in The Motor City...:banana: (Just a little...):burnout:
Tont
for the shifter bulb, it might put up a huge fight to get it out of the socket. Just wanted to warn you.
nipper
