mellow65 Posted November 14, 2007 Share Posted November 14, 2007 I am wanting to add a bung to the water outlet so i can run an after market temp gauge on a ej25 anyone ever had luck doing this or is it a waste of time. if it's not a crazy idea move on to the second part do you or do you know anyone that it pretty good with an aluminum welder, i just need an air tight weld, no crap if i can avoid it. ah hell it can look like crap if it needs to i just need it not to leak. Link to comment Share on other sites More sharing options...
mdoherty53 Posted November 14, 2007 Share Posted November 14, 2007 I was planning to do that myself but was hoping to slip the sender into the hose or maybe put a fitting in the top hose to fit the sender to I just found out that these temp gauges stay the same from about 160 to 205 deg f what are others experiences and temp readings Michael Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted November 14, 2007 Share Posted November 14, 2007 Im in Bellingham Wa I could have it welded Link to comment Share on other sites More sharing options...
uniberp Posted November 14, 2007 Share Posted November 14, 2007 I just found out that these temp gauges stay the same from about 160 to 205 deg f what are others experiences and temp readings Michael Do you mean the stock gauge? Can anyone confirm? I can easily see it, but if true and/or spec, then a modification/second gauge is very much in order. I mean, if you temp gauge read the same but is actually athe the top of the 205 range, that's pretty near 'uncomfortable'. Link to comment Share on other sites More sharing options...
mellow65 Posted November 14, 2007 Author Share Posted November 14, 2007 Im in Bellingham Wa I could have it welded i was pretty sure you were going to chime in, but damn it man you are soooo far away. with gas as much as it is i don't just go on my random road trips as much as i used to. i might check with the guys that i bought my welder from and see if there is any way of running aluminum through it. Link to comment Share on other sites More sharing options...
nipper Posted November 14, 2007 Share Posted November 14, 2007 I just found out that these temp gauges stay the same from about 160 to 205 deg f what are others experiences and temp readings Michael The factory gauges on the dash, i would say from 170-205. i know its quibling. I have confirmed this with my scangauge. nipper Link to comment Share on other sites More sharing options...
