FSRBIKER Posted November 16, 2007 Share Posted November 16, 2007 I figure this might be simple but on occasion I have the dash and headlights flicker for awhile while driving, usually below 3000 rpm. I have a new battery FYI. I figure it's the voltage regulator and I believe it's internal with the alternator...any other ideas before I get a new alternator? Link to comment Share on other sites More sharing options...
Cougar Posted November 17, 2007 Share Posted November 17, 2007 The problem may be with the internal regulator. Before replacing it I would have the alternator tested to see if it can produce full output and check the AC component of the output voltage also to make sure it isn't excessive. Link to comment Share on other sites More sharing options...
nipper Posted November 17, 2007 Share Posted November 17, 2007 Have the system tested, then price an ALT at one of the on line suppliers. Check all your engine grounds also. nipper Link to comment Share on other sites More sharing options...
