blaze Posted November 18, 2007 Share Posted November 18, 2007 I just installed a Brand New Subaru Short Block, in my 98 2.5 DOHC Outback. It had 197,000 miles and the head gasket blew. My question is the dealer gave me NGK PFR6B-11 spark plugs? My book calls for PFR5-11, but they said these are superceded to the 6's??? I've driven it for 200 miles with no problems, until tonight the check engine light came on? Coolant fine, oil fine, seems to be running smooth? Could these plugs be causing issue's? Link to comment Share on other sites More sharing options...
porcupine73 Posted November 19, 2007 Share Posted November 19, 2007 You need to read the ODBII code. Otherwise it's just a guess. Here's the NGK plug chart code descriptions: Link to comment Share on other sites More sharing options...
Rooster2 Posted November 19, 2007 Share Posted November 19, 2007 I doubt the spark plugs are the source of your CEL. It is highly unlikely that you would have fouled a plug in that short of milage. I use Bosch Platinum plugs in my Legacy OBW with no problems. Pull your codes to see what the problem is. My guess is the knock sensor, or 02 sensor. Link to comment Share on other sites More sharing options...
blaze Posted November 19, 2007 Author Share Posted November 19, 2007 Thanks I pulled the code today, it was P0420 CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD. I think the exhaust manifolds needed tightning? Still wonder if anybody else is using a colder plug? Or is it just my Dealer? Link to comment Share on other sites More sharing options...
porcupine73 Posted November 19, 2007 Share Posted November 19, 2007 Ah ok. P0420 is purely an emissions code. Typically for soobs it is either the rear o2 sensor, or the front o2 sensor. The front o2 sensor should be an OEM from the dealer. It can also be exhaust leaks. Sometimes people using aftermarket exhaust systems/cats get this code periodically. Soobs are fairly sensitive it seems for this one. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 19, 2007 Share Posted November 19, 2007 double check to make sure that all the wiring connectors are tight, especially after an engine change. then fronmt O2 sensor - OEM; then rear. i got this code in a 97OBW and it was a loose connection. Link to comment Share on other sites More sharing options...
cookie Posted November 20, 2007 Share Posted November 20, 2007 An exhaust leak could throw off the ox sensor. If the manifolds were leaking I'd start there. Link to comment Share on other sites More sharing options...
