Drum Brake Adjustment Question (EA81)
EA81T Wagon (1983). I'm bleeding the brakes on my wagon tonight & HTKYSA says to adjust the rear drums first. (Do I have to?)
It says to jack the car up to do this so you can rotate the wheel to make sure that the adjustment is right. Do I have to jack it up?(it's got a lift so i can access everything else w/o jacking it) Is there another way? Can I bleed the brakes w/o adjusting the rear drums?
Thanks,
- Noah
Yeah, they turned all the way in & the brake never touched (wheels turned)
Would that cause NO brake pedal pressure? Or is that indicative of a larger problem?
I decided to take the car to a shop tomorrow, I don't have all of the tools I need with me and I must drive the wagon home (200 miles) by Monday. I was quoted $160 + 80 (for new drums).
I wish I had the time and tools to do it; but, alas I just need it done.
Thanks for the info!
The EA-82 rear drum set-up will also swap over to the EA-81's. Just another option for you to get back on the road.
Yep - and some of them had auto-adjusters too. Weird contraption, and I don't like them since I had one completely eat itself and lock the wheel at freeway speeds. After I beat the drum off with a sledge there were all kinds of little brake "bits" and peices of the adjuster and the master cylinder. It looked like a grenade went off inside there. I have a feeling thats why they stopped using the auto adjusters later in the EA82 line.
People make a common mistake. When you replace shoes you really should replace the springs at the same time (no one does it). This avoids a failed self adjuster.
nipper
Well, I'm going to leave the car where it is for now and come back in early december w/ disk brakes to swap on.
While it's a fairly simple swap, It's way more work than changing shoes and drums on an old Drum set-up. You'd need calipers, rotors, hubs, and backing plates from a disc brake car. Figure the rotors you can get new and the calipers are easy to find new too(although spendy, about $75 a piece) Then you have to take it all apart, hope your brake lines aren't rusty, and bend the lines to match the disk brake fittings. Seems to me the disk swap would cost minimum of $200, and waaaayyyy more to have a shop do it(which they probably won't because of liability)
Who ever was gonna charge 160+80 for drums was overcharging you, at least for the drums. But even that would be easier and probably cheaper than the disk swap.
New drums or used ones with enough meat to turn should be 50 bucks, tops, after turning. Changing pads on these old drum set-ups, another $50 to $75,....maybe. That's 125 bucks for the whole job. Unless you are REALLY looking for performance from you're 25 year old economy car, I would go the easy and simple route and get new pads and drums. The adjuster should work fine then. Just don't forget to back out the adjuster before installing the shoes and drum.
My car has long since stopped being an little econo-car and is currently lugging 27" tires, which are hard to stop on the highway. I see this as a good opportunity to upgrade the brakes to something more appropriate for this car.
Is it hard to bend the hard-lines? Do I need a tool to do it w/o crimping them?
So, I CAN use the stock EA81 rear hard brake lines, then. Is it easier to pull the EA82T hard lines and install them on my car instead of rearranging the originals?
Also, it seems that the consensus according to most members is that a p-valve is unnecessary to swap into EA81 cars (and '82) because the drums operate on the same exact brake pressure as the rear disks do.
Also, I've never dealt with hard brake lines before, do I need any special tools? Will box-end wrenches or vice grips work?
You just bend the hard line into a "pig tail" and connect the EA82 soft line. No special tools are required.
You should use the proportion valve. I can tell you from experience it makes a difference. If you are running lifted it probably won't matter as much, but since the EA81's have no valve at all (EA82's all have them, and the disc valve is very little different from the drum valve) there's good reasons to install one, and no reasons that I know of not to - other than not wanting to do the extra labor. The cost of the valve is negligible
welll
You need a valve in the system because of the gap between the shoes and the drum.
Well instead of me explaining read this
http://www.howstuffworks.com/master-brake.htm
nipper
welll
nipper
Um - he's talking about the proportioning valve - not sure how that article relates.... EA81's didn't have a p-valve at all for the rear so it's definitely not required for any mechanical reasons.
oh thats right, hes going to 4 wheel disc brakes, my bad.
nipper
  • 3 weeks later...
Well, I could have started a new thread, but I figured I'd just continue this discourse:
I'm removing my rear drums and I can't get them apart!!
I've got the axle nut off and the wheels, but I can't pull the hub off the rear drum brakes. Any suggestions on how to do this? My understanding is that they just pull right off, but I've been hammering on it and yelling and spraying penetrating oil all over it and nothing is happening, please direct my anger to a constructive solution! (thanks)
Also, 1 of the axle washers (cone-type) doesn't want to come out and I don't have a brass punch handy, suggestions? (I haven't tried hammering a piece of wood on it yet . . . )
Thanks,
- Noah
So I figured out that turning the adjuster screw out all the way allows the hub to come off.
The adjuster nuts are all the way in; the first one came out no problem, the other one is getting stripped and won't turn. What do I do ?? I'm having the same problem disconnecting the hard brake lines from the back of the drums; they strip and won't turn any more; what do I do about these??
Replace the adjuster. That happens a lot actually. I've snapped a few completely off. If you can't get hte drum off beat it till the pads delaminate from their backing. It will come off, you just have to use brute force. Or if you have a really really big 3 jaw puller you might get it off that way too. Probably just push the axle through though.
Vice grips or a pipe wrench. You may have to replace that bit of hard line that runs down the control arm.
Sounds to me like you should be putting discs on it, or a complete, non crusty drum set at least. Those old manual adjustment drum setups are primitive and usually really crusty and difficult to work on. You may have to put some heat to parts of it if you wish to make them move again.
I AM doing a disk brake swap, it's just been a struggle today to remove the drums. I stopped working earlier when I ran into 2 screws that were stripping on me.
Can I get a replacement hardline readily from an auto parts store? Vice grips occurred to me this evening and I will try it. I'm not worried about destroying the adjuster screw, I just want it off!!
Thanks for the advice,
- Noah
