SakoTGrimes Posted November 24, 2007 Share Posted November 24, 2007 There's an XT (non turbo, ER27) at the local junkyard, will it's statrer work in my 87 wagon? I'm pretty sure it will but I want to be sure before I buy a non-returnable part. Link to comment Share on other sites More sharing options...
TomRhere Posted November 24, 2007 Share Posted November 24, 2007 Yep, starter will work on yours. So will the flywheel and clutch, 90 Amp alt is an easy swap to yours, tranny will swap if you should want full time 4WD, then there's all the stuff to do a 5 lug swap for better rim selection. Link to comment Share on other sites More sharing options...
daeron Posted November 24, 2007 Share Posted November 24, 2007 Yep, starter will work on yours. So will the flywheel and clutch, 90 Amp alt is an easy swap to yours, tranny will swap if you should want full time 4WD, then there's all the stuff to do a 5 lug swap for better rim selection. yah srsly, i would chop off my pinky toe (the right one, it has a deformed toenail anyhow. little freak.) to find an AWD XT6 in the junkyard. The only thing I would leave in it would be the engine and powersteering.. Unless the AC components were basically the same. Larger AC would be nice. Wheels, foglights, suspension/brakes/complete drivetrain, seats, steering wheel, heck I might even consider trying the stereo out if it worked, and if we were talking about for my GL-10, i would be looking at trip computer components. (might would do that anyhow.. I wanna see if i can hack one of those to run on an MSed car..... find a way to drive the soob VSS and drop the soob tank sender in, who knows?) Honestly, I would quite frankly try to buy the whole car, IF i could arrange that. can you tell i wanna see an XT6 show up in my junkyard? Link to comment Share on other sites More sharing options...
idosubaru Posted November 24, 2007 Share Posted November 24, 2007 XT6 automatic and manual starters are different. i do not think an automatic XT6 starter will work, but a manual trans XT6 starter should. Link to comment Share on other sites More sharing options...
Bucky92 Posted November 24, 2007 Share Posted November 24, 2007 Like I said on another post..if you need a starter and the one locally doesnt work..i gotcha covered if you want Link to comment Share on other sites More sharing options...
