Starkapopolis Posted December 6, 2007 Author Share Posted December 6, 2007 I've got a lead on a head from a jy in CO. Am looking into whether the part will be a match or not. Thanks for the tip! Hoping for the best, Brian Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted December 10, 2007 Author Share Posted December 10, 2007 I've got a lead on a head from a jy in CO. Am looking into whether the part will be a match or not. Thanks for the tip! Hoping for the best, Brian So that jy had a right head but it was bare of all its innards. If I get that, then I'll have to find the other parts (cams, shims, seals, etc) and have them machined to match, right? It sounds easiest to just find a used head that is complete. So far, I've found two cars that are parting out and both have a bad right head. What's up with the right always going south?! Still looking and taking the bus.http://www.ultimatesubaru.org/forum/images/icons/icon13.gif Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 10, 2007 Share Posted December 10, 2007 that legacy L you were looking at should have an EJ22, not an EJ25 like your car. although that is an easy swap, it drops right in, bolts right up and plugs right in. keep looking you should be able to find a good head. try posting in the parts wanted forum here. i saw a motor with blown headgaskets really cheap not too long ago, i think it was on here. that would have been a perfect candidate. the old head isn't repairable? I'm not sure if this was corrected or not but the EJ22 is a NON INTERFERENCE engine. wrong, edit your post please to keep other users from seeing that and "remembering it" in the future. this is very common and easy information: EJ22 up to 1996 is non-interference EJ22 1997+ is an inteference engine Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted January 13, 2008 Author Share Posted January 13, 2008 New update - same old news. I found a complete right head on ebay. bought it for $45! Was really happy with the way it was turning out. My mechanic finally gathered all the seals to put it in and he couldn't get enough compression. I think he said it was reading 90 pounds. Normal is around 130 - 150 right? He doesn't know if there's a hairline crack in the new used head or if something else is wrong with it, but his thinking is he's done trying to make that engine work. His suggestion is to either dump the car or replace the engine. btw - mechanic had a machine shop first look at the new head and verify it looked good. I had someone else eyeball it too. Nothing visible was seen. Also, the mechanic said they checked compression on both sides and made sure fuel was getting to both. It was. I know I won't get anything for it if I sell as is. Just redid whole A/C system AND brakes. Would rather fix if I can for under $1500. I know engines can be upwards of $2k but have seen a few online for 4-800. What's shipping like on one of those (2.5L DOHC automatic for 97 legacy). Thanks, Brian Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted January 13, 2008 Share Posted January 13, 2008 You need to find yourself a 2.2L 96 ,97, 98, Those will bolt right into your car. There is a ton of info on this site on the subject. Call the bone yards there's one out there. If the engine turns out to be bad they'll usually replace it unlike that head you bought on ebay. I have a very low opinion of the 2.5L engine I've had 2 in the same car both ended the same way a overheated mess. Every 2.2L I've had has been a jewel, 2.2's rule! Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 13, 2008 Share Posted January 13, 2008 If both cylinders are reading low and around the same pressure then I would suspect that the valve timing wasn't set right for that head. That will make the pressure read low. Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted January 15, 2008 Author Share Posted January 15, 2008 So the head didn't work - like that's going to stop me from throwing money down this endless pit - muhahahaha.. I found some ej25 dohc engines on ebay for pretty cheap. all of them say they are used and imported from Japan with around 40k miles and come with a 6 month, unlimited mileage warranty. their feedback ratings are excellent and the shipping price isn't too bad. anyone have concerns over using one of those engines? I'm not against the 2.2 idea, but I'm not doing this myself and am afraid my mechanic might not be up for a conversion if sensors and wires have to be tinkered with. I'll have a look at the instructions on the website and see how much is involved in case I decide to do the conversion. Thanks for any thoughts. Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 15, 2008 Share Posted January 15, 2008 Before you throw in the towel on the engine I would make sure that the timing belt was set up correctly on the head that is reading low. If the pressures are reading about the same for both cylinders on that side then my guess is the cam for the valves wasn't set correctly and could be a couple of teeth off. If you do get a used engine here is a link to a site that seemed good to me. http://www.jsamotors.com/ContactUs.aspx Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted January 15, 2008 Author Share Posted January 15, 2008 Thanks, Cougar. I'll ask the mechanic to check the timing belt and the cam. If that's not it, then I think I'll be looking at a new engine. I checked the link you sent. They do ship to residential which is nice, but the cost is quite a bit higher: $1400 total cost vs. $900 from my source. My mechanic had a question that maybe you folks can answer: do engines coming in from Japan have the same emissions set up or does that have to be tinkered with to make work in a US car. He cited previous problems with a Nissan using an imported engine. Thanks. Quote Link to comment Share on other sites More sharing options...
Cougar Posted January 15, 2008 Share Posted January 15, 2008 You can check out the FAQ's on the site I gave you. You will most likely have to swap some of the things from your old engine to the replacement one if you do that along with using your existing wire harness. Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 15, 2008 Share Posted January 15, 2008 i did a swap from a 2.5 to a 2.2 last winter and only had to move the accessories over.ie:alternator,a.c. ,oretty much the intake as well.it was very easy.the hardest part of all of it is the timing belt and that is simple as well. have faith in your ability to read and you can conquer this project.quit paying someone else and you can save some money.it is literally a plug and play affair with a bunch of new gaskets. on the other hand it does sound viable that the timing is simply off.cheers, brian Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted January 15, 2008 Share Posted January 15, 2008 When in doubt with a JDM engine exchange, just swap out the long block. An EJ25 is an EJ25 wether it's JDM or USDM. Use your intake & exhaust, and it will be plug & play. Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted January 15, 2008 Author Share Posted January 15, 2008 When in doubt with a JDM engine exchange, just swap out the long block. An EJ25 is an EJ25 wether it's JDM or USDM. Use your intake & exhaust, and it will be plug & play. Thanks, that's very helpful. I'd love to do this job myself, learn more about my car and save tons of money but there's just no time at the moment. Brian Quote Link to comment Share on other sites More sharing options...
monstaru Posted January 16, 2008 Share Posted January 16, 2008 i literally did it in a day and a half.going slow.a few hours prep,an hour there an hour here.then you vcan bust it out.there is no time if you don't make time. Quote Link to comment Share on other sites More sharing options...
Starkapopolis Posted January 16, 2008 Author Share Posted January 16, 2008 i literally did it in a day and a half.going slow.a few hours prep,an hour there an hour here.then you vcan bust it out.there is no time if you don't make time. Dang it all, now you've got me thinking about renting an engine hoist.. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted January 17, 2008 Share Posted January 17, 2008 You'd be better off buying one from Harbor Freight for $150-$200 and then selling it if you need the money. You'd make out better than renting one in my opinion. Wish I was there to help you out with this. IT's freakin cold up here. Quote Link to comment Share on other sites More sharing options...
