ABS diagnosis connector location
OK, I give. Ready to do the ABS sequence control, but I can't find the connector to jumper the terminals. I see the OBD II connector, and I see a white connector attached near the accelerator pedal sensor, but that one doesn't resemble the one I'm looking for. It's an '05 Legacy.
Hello. Well not sure if it's the same for yours, but here's the locations for an '00obw. '05 could be different. There is a specific order of steps that must be done for the sequence control. Basically for '00obw it's ground pins 3 and 6 and then stepping on and holding the brake pedal right after putting ignition to run. There are articles on http://www.endwrench.com search archives for abs.
Hi Sparky,
Don't mess with the white one hanging near the accel pedal, that aint it. Try the black, smaller one, closer to the brake pedal....my 2001 Forester had 2 wires hanging from it, presumably to use to jump the terminals. Let us know how it went.
