jbecker Posted November 26, 2007 Share Posted November 26, 2007 I have an 87 gl ea82t and i have heard that those motors need to run cool and the easiest way is to put a radiater from a automatic, all wheel drive, turbo car. I have this car as well and the radiater looks the same as the 87's radiater. Any help on what i should do. Thanks Jason Link to comment Share on other sites More sharing options...
john in KY Posted November 26, 2007 Share Posted November 26, 2007 All the EA82T engines basically take the same radiator. Turbo gets the 2 core radiator and everything else got the single core. As far as I know there was 2 "turbo" radiators and the only difference was the width. Auto/AWD/FWD/manual transmission...done of that makes any difference. Link to comment Share on other sites More sharing options...
DaveT Posted November 26, 2007 Share Posted November 26, 2007 The turbo are 2 row, thicker core. Same overall height & width. I put 2 rows in all my EA82s. I think it was the XT that used a wider radiator. The 2 row will make installing the clutch fan a little tighter. I have had to shorten the studs that hold the fan on the water pump on some. Recently got an all metal, 2 row, NOT made in china radiator here: http://www.usaradiator.com/index.php Link to comment Share on other sites More sharing options...
Gloyale Posted November 26, 2007 Share Posted November 26, 2007 Only the Turbo, 4EAT equiped cars had the 2 row radiator according to subaru literature. However, I bought a 88 Turbo GL, 4EAT, that only has a single core radiator. It cools fine. I towed a 2000 Lb trailer 2000 miles this summer in 100 degree heat, over mountains. In fact it over cools slightly, but that's probably a thermostat issue. Link to comment Share on other sites More sharing options...
calebz Posted November 27, 2007 Share Posted November 27, 2007 All the EA82T engines basically take the same radiator. Turbo gets the 2 core radiator and everything else got the single core. As far as I know there was 2 "turbo" radiators and the only difference was the width. Auto/AWD/FWD/manual transmission...done of that makes any difference. Lord, I wish 6 EA82T cars, not one factory 2 core My wagon has an oversized 2 core with metal tanks now. was a tiny bit tight getting it in, but I can sit in traffic all day with triple digit heat. Link to comment Share on other sites More sharing options...
