Anti-freeze question:
So I did a search on the forums and nothing came up. So I was wondering what type of Anti-freeze I should use in my EA82? Right now it's got the green stuff in it and that's how I bought in July 06. But I've heard that the green stuff is only for the older vehicles that have Cast-iron blocks? So what should I use? The Red GM coolant for Alui blocks or what?
Thank's
Tom
PS: I've also heard that the green fluid will couse Rust/corrosion?
MT Dew is YELLOW!:grin:
Coke has a red label:grin:
so Whatcha talkin 'bout mudduck!?:lol:
I just read my post, What was I talkin about? That made no sense!
The green anti-freeze won't cause corrotion if you DO change it evert year or two.
And I'm back to the Coke. I was drinking way too much of that Mountain Dew
I have used the green stuff almost 30 years. Don't change it much. Usually add in new if I have to open the coolant system as part of a repair. I never have seen any corrosion in any of the cooling system parts - cast iron pump impeller, aluminum block, brass radiator. My 1990 EA82 has been with me 15 years.
