Zero BEGS for a soob engine
1 Lucky Texan
s'ko and I got into a discussion about this very thing............
http://www.rqriley.com/doran.html
Though I have a turbocharged Saab set-up "in my pile" that I was thinking a bit more "traditional" with this:
http://www.freewebs.com/jzrusa/
(after the Loyale off roader, the V-6 motorcycle, and the diesel scooter)
Nice to see they finally updated the tri magnum. I still have the mechanix illustrated that came out in. I wanted one so bad when I was a kid :lol:
What is this saab turbo project you speak of? (I have had more saabs than soobs ;) )
Quick question(s):
Picture an outer axle carrier, front, Legacy, now where the strut mounts, instead there is an adapter that bolts through the strut mounting holes, giving a upper ball joint mount for a upper control arm.
If you wish you can take the time and trouble to down load this:
http://blackjackzero.com/media/buildguide.pdf
Page 10 top right picture
What is that piece called?
Can I buy one somewhere, or am I making them?
Ok, it would appear I am looking for a "spindle adapter bracket"
as can be seen here:
http://www.mustangandfords.com/projectbuild/mufp_0612_factory_five_cobra_roadster_part_7/photo_11.html
That one being for a Ford Mustang.
I also struck a website where they are modding a GM car of some sort. What they did was cut a strut, and weld in a machined top (plug), with a 3/4 grade 8 bolt sticking out (welded there) to which they attached a swivel end.
