1 Lucky Texan Posted November 26, 2007 Share Posted November 26, 2007 fyi http://blackjackzero.com/mainindex.htm Link to comment Share on other sites More sharing options...
Reveeen Posted November 26, 2007 Share Posted November 26, 2007 s'ko and I got into a discussion about this very thing............ http://www.rqriley.com/doran.html Though I have a turbocharged Saab set-up "in my pile" that I was thinking a bit more "traditional" with this: http://www.freewebs.com/jzrusa/ (after the Loyale off roader, the V-6 motorcycle, and the diesel scooter) Link to comment Share on other sites More sharing options...
calebz Posted November 26, 2007 Share Posted November 26, 2007 s'ko and I got into a discussion about this very thing............ http://www.rqriley.com/doran.html Though I have a turbocharged Saab set-up "in my pile" that I was thinking a bit more "traditional" with this: http://www.freewebs.com/jzrusa/ (after the Loyale off roader, the V-6 motorcycle, and the diesel scooter) Nice to see they finally updated the tri magnum. I still have the mechanix illustrated that came out in. I wanted one so bad when I was a kid What is this saab turbo project you speak of? (I have had more saabs than soobs ) Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 26, 2007 Author Share Posted November 26, 2007 that magnum seems more practical - and accesible - than that british zero. Hmmm- wonder if anyone has transplanted a Prius drivetrain into a lighter 'kit' type car? Carl Link to comment Share on other sites More sharing options...
Skip Posted November 26, 2007 Share Posted November 26, 2007 lest we forget my "Tri-mutation" started life as a "Tri-muter" also from Pop Mech Yea maybe we should forget it Link to comment Share on other sites More sharing options...
calebz Posted November 28, 2007 Share Posted November 28, 2007 lest we forget my "Tri-mutation"started life as a "Tri-muter" also from Pop Mech Yea maybe we should forget it The tri-muter was pretty cool. But I really wanted a tri-magnum when I was a kid. Link to comment Share on other sites More sharing options...
Reveeen Posted November 29, 2007 Share Posted November 29, 2007 Quick question(s): Picture an outer axle carrier, front, Legacy, now where the strut mounts, instead there is an adapter that bolts through the strut mounting holes, giving a upper ball joint mount for a upper control arm. If you wish you can take the time and trouble to down load this: http://blackjackzero.com/media/buildguide.pdf Page 10 top right picture What is that piece called? Can I buy one somewhere, or am I making them? Ok, it would appear I am looking for a "spindle adapter bracket" as can be seen here: http://www.mustangandfords.com/projectbuild/mufp_0612_factory_five_cobra_roadster_part_7/photo_11.html That one being for a Ford Mustang. I also struck a website where they are modding a GM car of some sort. What they did was cut a strut, and weld in a machined top (plug), with a 3/4 grade 8 bolt sticking out (welded there) to which they attached a swivel end. Link to comment Share on other sites More sharing options...
