blaze Posted November 26, 2007 Share Posted November 26, 2007 What is a good OBD2 Diagnostic scanner that can be used with my Laptop computer ? I see ESCAN is rated one of the best out there, but it cost to much for me. Some on ebay for around 50 bucks? But not sure if they will work with my 98 Outback 2.5 . Not interested in the hand held , perfer the ESCAN type. Something less than 100 bucks? Quote Link to comment Share on other sites More sharing options...
eryque Posted November 26, 2007 Share Posted November 26, 2007 OBDII is standardized, so any OBDII scanner will work. I've always been curious to know what the difference between the expensive scanners and the cheaps ones is. I picked up a cheap handheld one at Harbor Freight for $40. It returns a code and I look it up in the manual that comes with it. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 27, 2007 Share Posted November 27, 2007 There are 3 basic OBDII scanners. 1. The El-Cheapo: These scanners cost about $40. They blink the code with an led, which you read, then look up in a book. 2. The mid-range: These cost $70-$120. These have a basic one line screen that displays the code(s) in alpha-numeric order. You then look these up in a book 3. The super-scanners: These cost $199-$1200. These scanners read, and interpret the codes, giving you the code, and it's cause. They can also read ABS, Stability, chassis, Hvac. THey typically use cartridges, or can be upgraded via downloading new software. Included in these are PC, or PDA based code scanners. the best really depends on how/why you intend to use it. The average car owner can scrape by with an El-Cheapo. The more advanced owner can use the functionality of the mid-grade, as it can be used in a running diagnostic mode. The Master Tech, shop owner needs the super-scanner. They need to deal with all aspects of various cars. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 27, 2007 Share Posted November 27, 2007 Hello. Your posts title says "BEST OBD2 Diagnostic scanner". If you want the best for the soob, then you want the Subaru Select Monitor, available (as are all Subaru tools) from http://subaru.spx.com Quote Link to comment Share on other sites More sharing options...
JPX Posted November 27, 2007 Share Posted November 27, 2007 There are 3 basic OBDII scanners.1. The El-Cheapo: These scanners cost about $40. They blink the code with an led, which you read, then look up in a book. 2. The mid-range: These cost $70-$120. These have a basic one line screen that displays the code(s) in alpha-numeric order. You then look these up in a book 3. The super-scanners: These cost $199-$1200. These scanners read, and interpret the codes, giving you the code, and it's cause. They can also read ABS, Stability, chassis, Hvac. THey typically use cartridges, or can be upgraded via downloading new software. Included in these are PC, or PDA based code scanners. the best really depends on how/why you intend to use it. The average car owner can scrape by with an El-Cheapo. The more advanced owner can use the functionality of the mid-grade, as it can be used in a running diagnostic mode. The Master Tech, shop owner needs the super-scanner. They need to deal with all aspects of various cars. Mid-range is good. I have one of these that I bought specifically while chasing a code following a long-block swap. But I have used it numerous times on other cars since then.....totally worth it. Quote Link to comment Share on other sites More sharing options...
intravino Posted March 9, 2008 Share Posted March 9, 2008 Check ou this nice scanner: http://www.carplugs.com/obd2usb.html Quote Link to comment Share on other sites More sharing options...
OB99W Posted March 9, 2008 Share Posted March 9, 2008 Take a look at this site; includes useful links: http://www.obd2allinone.com/ Quote Link to comment Share on other sites More sharing options...
mrtoyou7747 Posted March 9, 2008 Share Posted March 9, 2008 I bought mine from Harrison R&D in TX. Connects to PC with USB port. He has several versions with different options. (OBDII, CAN bus, ABS eyc.) Enables you to see and record various sensor paramaters. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 9, 2008 Share Posted March 9, 2008 there's another thread recent thread (1 month or so) about this, i used it to purchase mine. i think mine was $30...$40 tops and it shows the code and what the code needs. it's awesome...portable, simple, and no need to look anything up. well worth such a small amount of change. i was going to go the laptop route too, but i'm glad i didn't. i've already used it a couple times and it's much simpler to carry that little thing out there than the lap top. i still may get a lap top version though just for kicks. Quote Link to comment Share on other sites More sharing options...
edrach Posted March 9, 2008 Share Posted March 9, 2008 I bought a laptop version a while back for around $90 shipped. You can download their software for free and play with it a bit before you decide to buy. Model BR-3. Works for me and I like it. www.obddiagnostics.com. Quote Link to comment Share on other sites More sharing options...
davebugs Posted March 9, 2008 Share Posted March 9, 2008 I have a 'sophisticated VW/Audi' setup for my laptop. This also includes ODBII. I have lots of other stuff on my laptop so it doesn't go out in the cold. When chasing a cylinder 3&4 misfire this spring I broke down and got a cheapie for 50 bucks on Ebay (with shipping). The same yellow one at the auto parts & Sears for 75-80. You have to look up the code in the book, or on your computer(they give you a CD). It is small enough to fit into the pocket of a coat which I found nice. The slightly better(and more expensive) readers won't fit in my coat pocket. Typically I'm looking for more of a possible explanation of a cause and troubleshooting that the readers seem to provide so I end up on the web anyways either here, Google, Endwrench, wherever. I needed the expensive VW one for my TDI. I like my cheapie. Dave Quote Link to comment Share on other sites More sharing options...
