LSD Swap Internals
Will a dremel tool work to remove the excess housing material? If I don't have an LSD housing handy for comparison, will it be apparent where to grind out?
There's pics somewhere of where you have to grind. Basically the bottom left side if looking at the back.
Can I remove my rear differential w/out removing both axles?
Nope, the axles have to come off. You have to pull the stub axles to get the innards out.
