prevent rust Brat rear shock mounts pics how to etc
this is how I plan to prevent rust of the Brat rear shock mounts, with pics here:
http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=14357
First off, I removed all dust, dirt, rocks from the rear part of the shock mount hollows on my CALI Brat. Next, I applied POR-15 rust paint over everything. Then I cut cardboard patterns for the foam packing stuff, to stuff in the hollows. Trimmed to fit so they are wedged in the hollows. Stuffed in, and seam sealed all around.
Next, cut trimmed and applied rubber membrane stuff over that, using seam sealer to attach, and seal off any gaps. Also seam sealed over the factory seams in that area. Then applied another coat of POR-15 over the membrane, and the seam sealer, then undercoated once dry
This should prevent any salt spray, etc crap to go behind the hollows which is what causes the rust.
A nice write-up; you should submit it to the USRM if you haven't already. Also, a good application of never-seeze compound on the bolts when mounting the shocks will go a long toward future problems with removing the bolts to replace the shocks.
yep, did put antisieze on the bolts, and also cleaned the threads of the bolts, and the nuts with tap and die set.
