xbalancex7 Posted November 30, 2007 Share Posted November 30, 2007 ok so I have a 1984 ea81 and it shuts off at idle or when driving while running after warmed up good. when cold it starts right up. first I believed it was a fuel problem. but checked that out and discovered real problem is lack of spark. with that being said, I have trouble shot it down to the reluctor and pickup inside the distributor. I am picking one up tomorrow to get the final answer but, I feel confident this IS the problem. Has anyone ever heard of such a problem before? a heat related lack of spark? It has got to be the pick up and not the coil. I tried both old coil and new coil, and same problem arises. I will let you guys know asap after I try the distributor pick-up/reluctor. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 30, 2007 Share Posted November 30, 2007 Well... I Believe that this Question Shall Goes Better at the "Older Gen" Forums... Have you checked the Fussible Main Links? ... it is just an Idea, but it Might Help... Good Luck! Link to comment Share on other sites More sharing options...
