crazyhorse001 Posted November 30, 2007 Share Posted November 30, 2007 After carefully considering my options after my HG failure on my wife's '97 Leggy with a 2.5 phase1. I'm wondering what engines will plug & play. It'll be easier to swap engines than to go the whole HG & rebuild route. The original engine smoked a bit, and had significant piston slap. C'mon y'all, what are my options on this OBDII equipped Leggy? WITHOUT having to rewire the whole car. Link to comment Share on other sites More sharing options...
FSRBIKER Posted November 30, 2007 Share Posted November 30, 2007 I KNOW FOR A FACT a 2002 2.5 from an Impreza will not plug and play. I then ended up buying a Jap replacement engine for $950 to my door, installed new head gaskets for piece of mind and it's been great ever since. After carefully considering my options after my HG failure on my wife's '97 Leggy with a 2.5 phase1. I'm wondering what engines will plug & play. It'll be easier to swap engines than to go the whole HG & rebuild route. The original engine smoked a bit, and had significant piston slap. C'mon y'all, what are my options on this OBDII equipped Leggy? WITHOUT having to rewire the whole car. Link to comment Share on other sites More sharing options...
idosubaru Posted November 30, 2007 Share Posted November 30, 2007 this is all over the site, start searching and reading up. what are you looking to do - keep the EJ25 or swap to an EJ22? rebuild or used? if rebuilt - just call CCR and they'll take care of you. if you're looking for used, start searching the forum all of this information is readily available. Link to comment Share on other sites More sharing options...
RallyKeith Posted November 30, 2007 Share Posted November 30, 2007 The EJ22 from an automatic 95 Legacy will swap right in. Must be an automatic donor car as the only the Automatics had EGR in 95. This is pretty well documented on the board. Link to comment Share on other sites More sharing options...
johnceggleston Posted December 1, 2007 Share Posted December 1, 2007 After carefully considering my options after my HG failure on my wife's '97 Leggy with a 2.5 phase1. I'm wondering what engines will plug & play. It'll be easier to swap engines than to go the whole HG & rebuild route. The original engine smoked a bit, and had significant piston slap. C'mon y'all, what are my options on this OBDII equipped Leggy? WITHOUT having to rewire the whole car. you can use 95 auto, 97, 98 EJ22 engines, and 96 auto with the y-pipe, (first piece of the exhaust). 95 and 96 are non-interferrence engines. 97 and 98 will have valve (maybe piston) damage if the timing belt brakes. Link to comment Share on other sites More sharing options...
