blk4est Posted December 1, 2007 Share Posted December 1, 2007 I've searched the forums and it seems that the throttle body might be the issue I'm dealing with,but I wanted to get everyones opinion from my exact situation. The car has trouble starting when it dips below 10 degrees, it will turn over so it seems to me to be a fuel issue. After I've started it and it has warmed up the car will start fine, but on first start up I have to gas it with the key pretty hard to get the car to fire up. Any ideas of what I can do to make this start easier since I don't want to be stranded someday. Would cleaning out the throttle body be the answer? or a new fuel filter? seafoam in tank? Thanks in advance guys. daniel Link to comment Share on other sites More sharing options...
archemitis Posted December 1, 2007 Share Posted December 1, 2007 i think the first question you will get is what year make and model is the car, what kind of efi do you have? assuming the throttle body you speak of is for efi Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 1, 2007 Share Posted December 1, 2007 Do you have an area you can plug a block heater into? Something like this? Link to comment Share on other sites More sharing options...
TomRhere Posted December 1, 2007 Share Posted December 1, 2007 I'll throw out a WAG and say it's fuel injected. So,,, with that assumption. I'll say it's probally related to the CTS or it's wiring, more than likely it's the wiring. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 1, 2007 Share Posted December 1, 2007 Coolant temp sensor, or the Idle Air Control valve. GD Link to comment Share on other sites More sharing options...
blk4est Posted December 1, 2007 Author Share Posted December 1, 2007 Sorry I left out some stuff i guess I was just being to general. Its a 90 loyale tbi. I don't have a place to plug in, or a garage. two votes for the coolant temp sensor. How come? Just trying to learn. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 1, 2007 Share Posted December 1, 2007 blk4est said: two votes for the coolant temp sensor. How come? Just trying to learn. The CTS tells the computer what temp the engine is at - if the computer thinks the engine is warmer than it really is, it will not engage the cold-start enrichment and will not provide enough fuel for cold starting. More fuel is required as the cold cylinder walls will cause condensation of the atomized fuel and will reduce the mixture to an unburnable state unless a richer mixture is used to compensate for this effect. GD Link to comment Share on other sites More sharing options...
blk4est Posted December 2, 2007 Author Share Posted December 2, 2007 Offhand do you know of a cheaper CTS sensor than autozone ($100). Online is fine. I was looking at partsbin but it said it was turbo only I assume they work across different car lines. Daniel Link to comment Share on other sites More sharing options...
Gloyale Posted December 2, 2007 Share Posted December 2, 2007 blk4est said: Offhand do you know of a cheaper CTS sensor than autozone ($100). Online is fine. I was looking at partsbin but it said it was turbo only I assume they work across different car lines. Daniel The MPFI/Turbo one has the same thread as the SPFI, and ouputs in same range. Different connector style though. It uses a Bosch/JECS standard Fuel injector plug, which you could buy and wire in. However...... this is a therory that it will work, I don;t know of anyone who has done it. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 2, 2007 Share Posted December 2, 2007 blk4est said: Offhand do you know of a cheaper CTS sensor than autozone ($100). Online is fine. I was looking at partsbin but it said it was turbo only I assume they work across different car lines. Daniel Before you go buying CTS's, check the connector to it for corrosion. And check the resistance range of the sensor. If you still need one, find a used one at the junk yard. If you can't find one there, they are about $40 at rockauto.com. GD Link to comment Share on other sites More sharing options...
The Dude Abides Posted December 2, 2007 Share Posted December 2, 2007 Sorry to hyjack but im having similar problems. Mine i half to tap the gas to get it going every time. When its colder i half to do it more though. But i notced i have no fast idle. Could this be the cts as well. Ben Link to comment Share on other sites More sharing options...
blk4est Posted December 2, 2007 Author Share Posted December 2, 2007 No problem. I have to do the same thing but after I keep it running I have a fast idle. I'm going out today to check the connections first. Daniel Link to comment Share on other sites More sharing options...
xbalancex7 Posted December 22, 2007 Share Posted December 22, 2007 I am working on a 1990 loyale with similar probs. it starts cold when I give it gas then idles super low 400rpm roughly 2 minutes later idle jumps up to over 3000 rpms then gradually proceeds to sink back down to 1500 rpms or so till fully heated then idles proper. I believe it is IAC (idle airflow solenoid) or the CTS unsure yet, I'm still working on it, let you know when I know for sure. both these items are very pricey 100 and over 300 from autozone. crazyness Link to comment Share on other sites More sharing options...
