djbroadus Posted December 14, 2003 Share Posted December 14, 2003 I would like to see some different ways to mount a cd player in the old suby Quote Link to comment Share on other sites More sharing options...
edrach Posted December 14, 2003 Share Posted December 14, 2003 If you have the patience and a dremel tool you can do what my youngest son did with his '83 wagon. He took out the heater control panel and moved it down to where the radio console was (needed an extra long cable from another wreck to reach the extra distance on one side). This left plenty of room for an EA82 style radio mounting bezel. He'll finish as soon as he figures out the speaker wiring. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 14, 2003 Share Posted December 14, 2003 Here is another EA81 console that was available. It lets you fit a standard CD stereo in the dash at an angle. Here it is mounted in my old Wagon with my old stereo and setup: I also have a similar setup in my brat now. Works pretty good. -Brian Quote Link to comment Share on other sites More sharing options...
subieman Posted December 14, 2003 Share Posted December 14, 2003 Here is my set up..... Quote Link to comment Share on other sites More sharing options...
Ma-fia Posted December 14, 2003 Share Posted December 14, 2003 I don't have a picture, but I went an easy way (well, easy for me): my center console was missing a radio anyway and was a bit cracked. With a dremmel I've cut out everything in the lower part where all the holes were (my console is more or less close to what Subieman has), then took a nice pine board, cut it to size, cut out rectangular opening, then trimmed to cover irregularities. A bit of lacquer -- and my fancy setup was ready. I just bolted it on from the inside with regular wood screws. I like the "wooden" look, but it could be painted to match the interior color perfectly. Not very stock, but it's there, looks neat and plays CDs. Hey, SubaruJunkie, is that shifter knob really olive GREEN like in your picture? I'd kill to find one llike it!! (You're not interested inselling are you?) Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted December 14, 2003 Share Posted December 14, 2003 Ed have him get a roll of cheap speaker wire at Walmart and rewire the whole thing it is much easier and you get rid of the common Ground thing.. If he is just doing this to see if he can keep it stock then i suggest using a AA battery with speaker wire taped to the ends to use as a lead. When He touchs the wires to the correct +&- wires then the speaker will pop and or hiss. You can mark them out with tape or whatever from there.. It took me 5 minutes to do it that way... After i went through and made sure i knew where the voltage wires were. Mike Quote Link to comment Share on other sites More sharing options...
