carfreak85 Posted December 3, 2007 Share Posted December 3, 2007 For those looking to upgrade the handling of their Gen 2 cars, the route is fairly simple. By using factory parts and the upgrade path forged by FHI we can lower our cars a few inches without hurting the ride too badly. Mine is 4WD but this should also apply to 2WD cars, but the effects will be less in the front. FRONT: For the front, find some EA81T front springs as they are almost .5" shorter with a slightly higher spring rate. Then source some 2WD front struts since the miminum length is over an inch shorter than a 4WD strut as well as having a longer stroke (always a good thing for McPherson strut suspensions). Make sure that you install the strut tops so they match your drivetrain. Thats it, we're done! Put the new parts back in! REAR: The rear is almost easier. Again, find a set of 2WD rear struts and install them. To lower the rear, just unbolt the trailing arm and the small bolt on the bottom of the torsion bar housing. Hammer out the torsion bar ONE AT A TIME and reclock by one notch. Two is possible, but unless you remove your bumpstops the ride will suffer. Finished! NOTE: I lowered my wagon by one notch in the rear and it still contacts the bump stops on some bumps. I trimmed them and the ride improved, so you can fix the problem by trimming an inch or so off the rear bump stop. Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 3, 2007 Share Posted December 3, 2007 Looks good man. I"m glad someone finally did a pictoral post on the matter. I was just too lazy, lol. Link to comment Share on other sites More sharing options...
newsoobdude Posted December 3, 2007 Share Posted December 3, 2007 Man, that wagon looks sweet lowered . Link to comment Share on other sites More sharing options...
crazyhorse001 Posted December 4, 2007 Share Posted December 4, 2007 NIIIIIICCCEEE!!!! I do believe that's the 1st LOWERED EA81 I've seen. 1 Link to comment Share on other sites More sharing options...
hatchsub Posted December 4, 2007 Share Posted December 4, 2007 crazyhorse001 said: NIIIIIICCCEEE!!!! I do believe that's the 1st LOWERED EA81 I've seen. You've never seen this? http://www.ultimatesubaru.org/brats/cbrat/cbrat.html Link to comment Share on other sites More sharing options...
Ross Posted December 4, 2007 Share Posted December 4, 2007 thought i'd add that after loosening the three arm bolts on the rear, you'll need to do a wheel alignment.... 1 Link to comment Share on other sites More sharing options...
mudduck Posted December 4, 2007 Share Posted December 4, 2007 Unrealated to lowering the car, but what are the mudflaps under the car for? Just curious. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 4, 2007 Share Posted December 4, 2007 mudduck said: Unrealated to lowering the car, but what are the mudflaps under the car for? Just curious. They are supposed to deflect debris from the CV boots in the rear. Branches, ect. Some of us have added larger rubber flaps to offer greater protection. GD 1 Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 4, 2007 Share Posted December 4, 2007 Galen, now that you did that, it needs an alignment. The 3 bolts that you took out of the trailing arms are actually the rear toe adjustments. So, better get on that whole alignment thing. I gotta do the back end of my coupe for the same reason. My rear toe is out of spec and its a real b**** to adjust it:rolleyes: Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted December 4, 2007 Share Posted December 4, 2007 Caboobaroo said: Galen, now that you did that, it needs an alignment. The 3 bolts that you took out of the trailing arms are actually the rear toe adjustments. So, better get on that whole alignment thing. I gotta do the back end of my coupe for the same reason. My rear toe is out of spec and its a real b**** to adjust it:rolleyes: You sure it ain't the bearing? That's always been my case. That or bent control arm. Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 4, 2007 Share Posted December 4, 2007 SOOBOUTLAW said: You sure it ain't the bearing? That's always been my case. That or bent control arm. Umm yes, especially since I do alignments for a living;) Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 4, 2007 Share Posted December 4, 2007 crazyhorse001 said: NIIIIIICCCEEE!!!! I do believe that's the 1st LOWERED EA81 I've seen. Maybe you missed these as well. http://www.ultimatesubaru.org/forum/showthread.php?t=75074 http://www.ultimatesubaru.org/forum/showpost.php?p=592661&postcount=7 Link to comment Share on other sites More sharing options...
kiwi subbie Posted December 4, 2007 Share Posted December 4, 2007 cool:burnout: Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted December 6, 2007 Share Posted December 6, 2007 Caboobaroo said: Umm yes, especially since I do alignments for a living;) I could have sworn the rear was non adjustable. How do you manage to adjust the rear? Link to comment Share on other sites More sharing options...
subiemech85 Posted December 6, 2007 Share Posted December 6, 2007 where's the ground clearance????? Link to comment Share on other sites More sharing options...
Ross Posted December 6, 2007 Share Posted December 6, 2007 SOOBOUTLAW said: I could have sworn the rear was non adjustable. How do you manage to adjust the rear? loosen the three bolts holding torsion bar arm to control arm and move hub assembly around..... takes some practice to get it right. Link to comment Share on other sites More sharing options...
mudduck Posted December 6, 2007 Share Posted December 6, 2007 subiemech85 said: where's the ground clearance????? Lowrider 4wd I bet its fun in packed snow and ice! Link to comment Share on other sites More sharing options...
carfreak85 Posted December 6, 2007 Author Share Posted December 6, 2007 mudduck said: Lowrider 4wd I bet its fun in packed snow and ice! More like just lowrider, hahaha. Its in RWD mode right now. Link to comment Share on other sites More sharing options...
573417h Posted June 23, 2020 Share Posted June 23, 2020 Thread dredge here.. any chance of getting pics reuploaded for the 1st post. Thanks 1 Link to comment Share on other sites More sharing options...
franbev Posted June 23, 2020 Share Posted June 23, 2020 On a Brat the ride height is adjustable front and rear. In the front, the lower spring perch has adjusters. In the rear, there is a 19mm bolt on the center of the torsion bar to raise and lower the rear end. 1 Link to comment Share on other sites More sharing options...
carfreak85 Posted June 23, 2020 Author Share Posted June 23, 2020 On 6/23/2020 at 8:55 AM, 573417h said: Thread dredge here.. any chance of getting pics reuploaded for the 1st post. Thanks Expand I don't have the photos anymore, the hard drive was damaged years ago. @franbev this thread has nothing to do with the factory height adjustment. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted June 24, 2020 Share Posted June 24, 2020 Factory height adjustment on the front end will only raise the ride height above the stock ride height. It’s not recommended to drive with these wound all the way up on the open road. Cheers Bennie Link to comment Share on other sites More sharing options...
573417h Posted June 26, 2020 Share Posted June 26, 2020 Thanks guys looking for clear way of doing this... if easily accomplished Link to comment Share on other sites More sharing options...
carfreak85 Posted June 26, 2020 Author Share Posted June 26, 2020 It's quite simple to lower an EA81, I typed the instructions out in the first post. The pictures would be nice to reference, but it's literally remove and replace the 4WD struts/shocks with 2WD parts. Re-clocking the torsion bar is the most difficult part and even that is quite straight forward, even if it takes some finesse to free the bar/trailing arm assembly from the torsion bar tube and rear height adjustment mechanism. Link to comment Share on other sites More sharing options...
