idosubaru Posted December 4, 2007 Share Posted December 4, 2007 anyone have much luck removing stuck ABS sensors with a sheared off bolt head? doesn't look like much room for a drill but i have a right angle attachment. once the sensor is off are the bolts usually frozen in the hubs too? i have new ABS sensors so i don't mind ruining the old ones to get the bolt out. Link to comment Share on other sites More sharing options...
john in KY Posted December 4, 2007 Share Posted December 4, 2007 Have a set of sensors from some turbo hubs I bought a few years ago. Wish I had known you were needing some. Can't visualize where the sensors are located but bet if you just pulled the complete hub that sheared bolt could be easily gotten to. Link to comment Share on other sites More sharing options...
idosubaru Posted December 4, 2007 Author Share Posted December 4, 2007 they are very easy to replace, but i really don't want to pull the hub. you can actually replace them without even jacking the car up, just turn the wheel and reach around the tire from the front of the car. a couple minute job literally (minus the rust of course). thanks for the offer john, i already have two new sensors. they wear so much (maybe it's just this area, snow and such) that i wanted brand new ones on mine. Link to comment Share on other sites More sharing options...
tomson1355 Posted December 4, 2007 Share Posted December 4, 2007 Gary, I drilled mine out easily to a 1/4" bolt. There is room on the outside (the tire side) for a nut. The problem I had and which you won't face is how to get the sensor itself out. Mine was really stuck and I'm sure I damaged it prying on it. It went back in tightly, too. Link to comment Share on other sites More sharing options...
