howards11 Posted December 14, 2003 Share Posted December 14, 2003 Are there any suggestions for a 2000 Forester L ? They take 205/70R15. I've been looking at BF Goodrich Radial Long Trail T/A. Any comments would be appreciated. Thanks! ~Howard Link to comment Share on other sites More sharing options...
Forester_Ranger Posted December 14, 2003 Share Posted December 14, 2003 you should have no problem fitting the BF Goodrich Long trail 205/75r15 on your Forester. I ran 205/75r15 Coopers Discoverers for a long time with no issues. Don't go any taller than 205/75r15 or you'll probably won't have enough clearence between the top of the rear tire and strut. But that can be solved with customized strut lift. Link to comment Share on other sites More sharing options...
howards11 Posted December 14, 2003 Author Share Posted December 14, 2003 Originally posted by Forester_Ranger you should have no problem fitting the BF Goodrich Long trail 205/75r15 on your Forester. I ran 205/75r15 Coopers Discoverers for a long time with no issues. Don't go any taller than 205/75r15 or you'll probably won't have enough clearence between the top of the rear tire and strut. But that can be solved with customized strut lift. To keep everything simple I'm sticking with the original size. ~Howard Link to comment Share on other sites More sharing options...
Dr Farco Posted December 14, 2003 Share Posted December 14, 2003 While we're talking tires, I have a 98 O/B which is new to me. It of course has AWD. The question is, do I replace all four at once, as in other 4X4's? Or can I replace the two bad tires I have. One has a cut in the sidewall and another just leaks.(picked up a large screw.) They all are in good shape with 3/4 tread. Link to comment Share on other sites More sharing options...
Commuter Posted December 14, 2003 Share Posted December 14, 2003 As per Subaru's instructions, tires are to be within 1/4" on the circumference. That amounts to just 1mm (sorry for mixed units) of tread depth variation. If you have a couple of good tires, you could see if anyone can shave new ones for you to bring them down to match. I don't know the cost of that, or how readily you could find the service. And I probably wouldn't bother if the old ones are more than a year or 2 old. Rubber ages, etc. Commuter Link to comment Share on other sites More sharing options...
howards11 Posted December 14, 2003 Author Share Posted December 14, 2003 Originally posted by Dr Farco While we're talking tires, I have a 98 O/B which is new to me. It of course has AWD. The question is, do I replace all four at once, as in other 4X4's? Or can I replace the two bad tires I have. One has a cut in the sidewall and another just leaks.(picked up a large screw.) They all are in good shape with 3/4 tread. I would not fool around with the old tires or shaving the new ones. I'd just replace all four. ~Howard Link to comment Share on other sites More sharing options...
Crashton Posted December 14, 2003 Share Posted December 14, 2003 Howard, My recommendation still stands. http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=4926 The Yoko's are very good tires at a bargain price.:santa: Chuck Link to comment Share on other sites More sharing options...
Forester_Ranger Posted December 21, 2003 Share Posted December 21, 2003 Originally posted by howards11 To keep everything simple I'm sticking with the original size. ~Howard From what I've seen on the BF Website. the long trail doesn't come in your original size. Your Forester came with a 70 series and the closest Long Trail to your size is a 75 series. which is a taller tire than your orginal. Link to comment Share on other sites More sharing options...
howards11 Posted December 21, 2003 Author Share Posted December 21, 2003 Originally posted by Forester_Ranger From what I've seen on the BF Website. the long trail doesn't come in your original size. Your Forester came with a 70 series and the closest Long Trail to your size is a 75 series. which is a taller tire than your orginal. I don't know where you have been looking but the Long Trail do come in 205/70R15. However two tire dealers in my area told me that the factory is backordered until Feb. 2004. I needed tires ASAP as the original Duelers were not giving me any traction in a recent 2" snow (I had no problems DRIVING. STOPPING was another story.). I settled for Bridgestone Turanza LS-T in a P205/70R15. These Bridgestones had a very nice review at tirerack.com. The dealer suggested running them @ 35 PSI. ~Howard Link to comment Share on other sites More sharing options...
Crashton Posted December 21, 2003 Share Posted December 21, 2003 Glad you got your tires. Tires are so much cheaper than bodywork. Link to comment Share on other sites More sharing options...
