ImprezaPo Posted December 4, 2007 Share Posted December 4, 2007 1998 Impreza 2.2l hatchback Oil has collected on the top of the exhaust pipe and is burning off. It's sort of where the manifolds connect to a straight pipe under the dash on passenger side. Here's an archaic exhaust picture where the arrow shows where the oil is burning off on. \ / \ / | <--------- Any idea where that would be coming from? There are a couple of drops of oil dripping from the car on my garage floor but nothing significant. Oil level is fine too. Link to comment Share on other sites More sharing options...
e4620 Posted December 4, 2007 Share Posted December 4, 2007 Could be a leaking oil seperator plate. Out of curiosity, how many miles are on the car? Link to comment Share on other sites More sharing options...
ImprezaPo Posted December 4, 2007 Author Share Posted December 4, 2007 88k e4620 said: Could be a leaking oil seperator plate. Out of curiosity, how many miles are on the car? Link to comment Share on other sites More sharing options...
ImprezaPo Posted December 4, 2007 Author Share Posted December 4, 2007 Other than the annoying smell, i guess it's not that big of a deal and a classic subaru problem? Thanks for the info. about the oil seperator plate! Link to comment Share on other sites More sharing options...
x_25 Posted December 4, 2007 Share Posted December 4, 2007 My '99 OBW did that for a while. I can't remember what the problem was though, it was some seal leaking and the dripping oil would fly back onto the exhaust pipe and make big clouds of smoke. It would be fun, we would go to a gas station and there would be a bit coming in the vents so we would open the hood to let out a giant cloud of smoke and everyone would . twas fun apart from the smell and the adding of oil. Link to comment Share on other sites More sharing options...
xrturbo Posted December 4, 2007 Share Posted December 4, 2007 You will prob. find one of three things: pass side inner axle boot, sep plate or cam support o ring on pass head. Link to comment Share on other sites More sharing options...
nipper Posted December 4, 2007 Share Posted December 4, 2007 Many possabilities. The cam seals, Main engine seal in the front, oil pump seal. Axle boots dont have grease that travel that far.The sperator plate doesnt usually leak that bad to get on that pipe, as it is trapped by the blel housing. First thing to do is go to a self service car wash and wash the bottom of the engine. This is what a shop would do to see where the leak is coming from. Have you ever replaced the timing belt? If so how long ago. nipper Link to comment Share on other sites More sharing options...
ImprezaPo Posted December 4, 2007 Author Share Posted December 4, 2007 Timing belt has not been replaced. It has 88k on it. Is it due already? nipper said: Many possabilities. The cam seals, Main engine seal in the front, oil pump seal. Axle boots dont have grease that travel that far.The sperator plate doesnt usually leak that bad to get on that pipe, as it is trapped by the blel housing. First thing to do is go to a self service car wash and wash the bottom of the engine. This is what a shop would do to see where the leak is coming from. Have you ever replaced the timing belt? If so how long ago. nipper Link to comment Share on other sites More sharing options...
nipper Posted December 5, 2007 Share Posted December 5, 2007 ImprezaPo said: Timing belt has not been replaced. It has 88k on it. Is it due already? er its just a wittle late..... Just a wittle .... a tiny bit ... http://www.cars101.com/subaru/subaru_maintenance.html every 60,000 miles or 60 months. Its after 2000 that it jumps to 105,000 miles. nipper Link to comment Share on other sites More sharing options...
subyfreak Posted December 5, 2007 Share Posted December 5, 2007 My 92 Legacy and 91 Legacy both leak from the valve covers most noticeable just after driving and while sitting at idle. Leaks right on the exhaust. It's time for my 200,000 mile gasket change. Just a place to look. Good luck. Link to comment Share on other sites More sharing options...
welly Posted December 5, 2007 Share Posted December 5, 2007 I did my first oil and filter change (for me) on my Suby recently. It had been using oil (which was unusual) and ever since the previous dealer service at 90,000 miles it had been smelling a bit. When I got under the car there was quite a bit of oil around. I found that the dealer had not tightened the sump plug up enough- it was only finger tight!. I now hope the car is back to no oil consumption as before. Link to comment Share on other sites More sharing options...
ImprezaPo Posted December 5, 2007 Author Share Posted December 5, 2007 I bought the car from a dealer last month, so I actually don't know if it's been replaced. I'm guessing it would be really hard to tell. Are oil leaks like this a common side effect of an old timimg belt? What would you expect to pay for a timing belt replacement on this car? nipper said: er its just a wittle late..... Just a wittle .... a tiny bit ... http://www.cars101.com/subaru/subaru_maintenance.html every 60,000 miles or 60 months. Its after 2000 that it jumps to 105,000 miles. nipper Link to comment Share on other sites More sharing options...
nipper Posted December 5, 2007 Share Posted December 5, 2007 ImprezaPo said: I bought the car from a dealer last month, so I actually don't know if it's been replaced. I'm guessing it would be really hard to tell. Are oil leaks like this a common side effect of an old timimg belt? What would you expect to pay for a timing belt replacement on this car? Oil leaks are common to subarus as the get older. This car is a little young for them, but the low mileage can be just as bad as high mileage on a seals. Last time i did this i had everything replaced up front and it was 700.00 ish (re seal everything timing belt water pump tensioner). Why not do it yourself? This is a SOHC so its much easier then the 2.5L nipper Link to comment Share on other sites More sharing options...
xrturbo Posted December 5, 2007 Share Posted December 5, 2007 nipper said: Many possabilities. The cam seals, Main engine seal in the front, oil pump seal. Axle boots dont have grease that travel that far.The sperator plate doesnt usually leak that bad to get on that pipe, as it is trapped by the blel housing. First thing to do is go to a self service car wash and wash the bottom of the engine. This is what a shop would do to see where the leak is coming from. Have you ever replaced the timing belt? If so how long ago. nipper The oil is not normally contained in the bell. There is a cover plate on the underside of the torque converter that is almost always removed and discarded if the engine or trans has ever been removed. Whenever the inner axle boot on the passenger side tears it throws the grease onto the front cat conv. Granted it is unlikely that it will travel into the Y, but it is possible Link to comment Share on other sites More sharing options...
nipper Posted December 5, 2007 Share Posted December 5, 2007 xrturbo said: The oil is not normally contained in the bell. There is a cover plate on the underside of the torque converter that is almost always removed and discarded if the engine or trans has ever been removed. Ah my last two soobies had them, thats why i never noticed the leaks in either of them till something else went wrong. nipper Link to comment Share on other sites More sharing options...
MilesFox Posted December 5, 2007 Share Posted December 5, 2007 valve cover gasket Link to comment Share on other sites More sharing options...
xrturbo Posted December 5, 2007 Share Posted December 5, 2007 nipper said: Ah my last two soobies had them, thats why i never noticed the leaks in either of them till something else went wrong. nipper It is soooooo much easier if you pull them off when you go to reinstall either item. The first one I tried to leave on and I didn't notice that it bent upward and went into the ring gear on the flywheel..... man did that make a nice noise:grin: Link to comment Share on other sites More sharing options...
