85 subi gl blown can i swap 2 a newer ea82
the h4eads on the spfi will be missong the ports for all that anti backfire tubing running off the back of the heads. you can eliminate all that. you wi;ll gain compression with using the spfi longblock and the carb intake. other than that, it will all fit the same
