nmiley Posted December 7, 2007 Share Posted December 7, 2007 i have recently bought a '91 lagacy ls w/ 138k for $2,000. i thought that it was a great purches but i recently found out that the clutch pack is blown and i'm opperating w/ only one wheel drive. not so cool at 8,000 ft. in the winter. i have found a 50k tranny from japan for $950, $50 for delivery. installed that would be $1,350 +. i'm tempted, but i can see that there are other problems right around the corner(i.e. suspension, oil leaks repair, tires). taking suggestions, should i take the plunge or cut my losses? Link to comment Share on other sites More sharing options...
porcupine73 Posted December 7, 2007 Share Posted December 7, 2007 Hm...that trans price seems a bit high. A similar year used USDM 4EAT should be a couple hundred dollars at most? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 7, 2007 Share Posted December 7, 2007 You can replace *just* the clutch pack. There's no need to replace the whole tranny, or even remove it from the car. The transfer clutches are in the rear output, which can be seperated from the rest of the transmission. Do a search here for "torque bind" as this will detail the procedure for R&R'ing the transfer clutches. That's very low mileage for a 91 overall. Besides the transmission I would be looking at making sure the timing belt has been done (should have been due around 120k). If not then the oil leaks can be addressed at the same time. Maintenance is a reality. If you can't handle it and see the obvious benefits to that course of action (no payments, low insurance, etc) then perhaps a new car is right for you - you will get a warrantee, and a gauranteed monthly payment. Instead of you deciding how to spend your money the bank and insurance agency will decide for you. Invest in some tools - you'll save money, and know the job is done right. Plus it gives you a freedom that most car owners never experience. GD Link to comment Share on other sites More sharing options...
Manarius Posted December 7, 2007 Share Posted December 7, 2007 Throw into the mix also that JDM transmissions work differently than USDM transmissions. You'd need the JDM TCU to make the JDM transmission actually work. It'd be a big hassle to install that transmission because the electronics are different. Link to comment Share on other sites More sharing options...
stevetone Posted December 7, 2007 Share Posted December 7, 2007 i have recently bought a '91 lagacy ls w/ 138k for $2,000. i thought that it was a great purches but i recently found out that the clutch pack is blown and i'm opperating w/ only one wheel drive. not so cool at 8,000 ft. in the winter. i have found a 50k tranny from japan for $950, $50 for delivery. installed that would be $1,350 +. i'm tempted, but i can see that there are other problems right around the corner(i.e. suspension, oil leaks repair, tires). taking suggestions, should i take the plunge or cut my losses? You bought a 16 year old car with (at least) 138,000 miles on it -- how exactly would you "cut your losses?" If you sold it you would likely get far less than the $2,000 you paid for it (unless you did not disclose the defects to the next buyer), so you'd still be out some dollars. I am continually amazed when someone buys a used, tired old car and does not think that it will need any maintenance or repair work. Come on! Fix the problems and enjoy the car -- even with the repairs it cost a whole lot less than a new one. Grumpy this morning, Steve Link to comment Share on other sites More sharing options...
uniberp Posted December 7, 2007 Share Posted December 7, 2007 i have recently bought a '91 lagacy ls w/ 138k for $2,000. i thought that it was a great purches but i recently found out that the clutch pack is blown and i'm opperating w/ only one wheel drive. not so cool at 8,000 ft. in the winter. i have found a 50k tranny from japan for $950, $50 for delivery. installed that would be $1,350 +. i'm tempted, but i can see that there are other problems right around the corner(i.e. suspension, oil leaks repair, tires). taking suggestions, should i take the plunge or cut my losses? Look for a tranny on http://www.car-part.com. Subaru auto trannys are suppose to be pretty tough, so chances are you'll get a decent one used. There's a thread here about the longevity of the sube auto trans. Link to comment Share on other sites More sharing options...
CNY_Dave Posted December 7, 2007 Share Posted December 7, 2007 The clutch pack is slipping? Is this a common failure mechanism, I thought for the most part they worked, or they were bound up? Dave Link to comment Share on other sites More sharing options...
ericem Posted December 8, 2007 Share Posted December 8, 2007 Did you try changing the transmission fluid first? Maybe throw in some additives like lucas transmission fix. Link to comment Share on other sites More sharing options...
nipper Posted December 8, 2007 Share Posted December 8, 2007 At that age it wouldnt be surprising to have the clutch pack tired. First thing to do is change the fuid. If that doesnt work I would look for a used tranny, its just easier and faster to deal with the rebuilding the clutch pack. nipper Link to comment Share on other sites More sharing options...
