sam888 Posted December 8, 2007 Share Posted December 8, 2007 If I understand things right the Outback in addition to longer strut assemblies and larger tires also has a lift kit that comes stock. I was just wondering if the lift kit that comes stock on an Outback can be removed? I am thinking of the installing Outback struts and springs on my 91 Legacy LS and if possible I would also like to add the Outback Lift kit. Link to comment Share on other sites More sharing options...
Hondaslayer Posted December 8, 2007 Share Posted December 8, 2007 sam888 said: If I understand things right the Outback in addition to longer strut assemblies and larger tires also has a lift kit that comes stock. I was just wondering if the lift kit that comes stock on an Outback can be removed? I am thinking of the installing Outback struts and springs on my 91 Legacy LS and if possible I would also like to add the Outback Lift kit. It kind of works that way. It is not a full on lift per'se, but just a couple blocks between the front and rear x-members (and the front of the diff x-member) to help keep camber and toe in check. You might need the pitch stopper, steering joint and radiator hoses as well. Link to comment Share on other sites More sharing options...
Gloyale Posted December 8, 2007 Share Posted December 8, 2007 I think you need the control arm mounts a well. Since the front end of the of the control arm is bolted to the crossmember, and the other is bolted to the unibody. Between the crossmember there is a block, or spacer. There is no block at the unibody mount however, so you need need the taller mount forn the outback or to fashion a block. At the rear, the trailing arm mounts are a similar affair. However I suspect that because of the length of the arms and the nature of the design, you can get away without swapping those. In fact they may not even be any different come to think of it. Seems to me that using just the ouback struts and no blocks to lift gives you the best real ground clearance advantage. The drive train stays up high, all the lift transfer to actual inches of clearance. Stress on the drivetrain I suppose would be the only worry, but seems minimal. Link to comment Share on other sites More sharing options...
pheonix165 Posted December 9, 2007 Share Posted December 9, 2007 why bother with the outback stuff. if you use the wrx struts and springs you will get between 1.5-2" lift depending on how bagged your current springs are. it'll look like this Link to comment Share on other sites More sharing options...
subaru360 Posted December 9, 2007 Share Posted December 9, 2007 Yeah, the outback blocks don't give any extra height. You could get them out and install them. I think they might be spot welded to the crossmembers, I don't recall exactly. If they are it's just a matter of breaking the spotwelds. They just lower the drivetrain for better angles on the C/V joints. Lots of people seem to be running the Outback struts without the blocks and don't seem to be having any trouble. What you might want to look into is the Outback rear trailing arms, I think they are longer. Some of the older leagacy's I've seen lifted have the rear wheels pulled forward. I think the longer outback arms will help with that. Gloyale said: I think you need the control arm mounts a well. Since the front end of the of the control arm is bolted to the crossmember, and the other is bolted to the unibody. Between the crossmember there is a block, or spacer. There is no block at the unibody mount however, so you need need the taller mount forn the outback or to fashion a block. At the rear, the trailing arm mounts are a similar affair. However I suspect that because of the length of the arms and the nature of the design, you can get away without swapping those. In fact they may not even be any different come to think of it. Seems to me that using just the ouback struts and no blocks to lift gives you the best real ground clearance advantage. The drive train stays up high, all the lift transfer to actual inches of clearance. Stress on the drivetrain I suppose would be the only worry, but seems minimal. Link to comment Share on other sites More sharing options...
Tide13 Posted December 9, 2007 Share Posted December 9, 2007 pheonix165 said: why bother with the outback stuff. if you use the wrx struts and springs you will get between 1.5-2" lift depending on how bagged your current springs are. it'll look like this Sweet looking ride. Where'd you get the light bar? Link to comment Share on other sites More sharing options...
pheonix165 Posted December 10, 2007 Share Posted December 10, 2007 room-mate made it. it's actually his car....for now any way Link to comment Share on other sites More sharing options...
sam888 Posted December 12, 2007 Author Share Posted December 12, 2007 Thanks to who responded to my question. I think I'm going lift my subaru by using just the OB Struts and springs. I don't have the cash to do it know so it will have to wait until maybe this summer. I will post some pictures when it is done. sam Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 20, 2007 Share Posted December 20, 2007 You don't need the outback springs. My dad's legacy brighton on outback struts only is the same height as my mom's outback. The springs don't get you any more lift unless you get King Springs. If you do put lift springs on, I would put the crossmember drops in. Link to comment Share on other sites More sharing options...
Mike W Posted December 20, 2007 Share Posted December 20, 2007 I guess I could see that being the case if your Mom's Outback is a '95 or early '96. I have '97 OB struts with '93 springs on my '93 Legacy and I can barily cram Outback size tires under it. When I get time I'll be installing a set of 97' OB struts with OB springs. That'll raise it another inch or so and might stiffen the ride a little. I had good luck with the last set of reman axles so I'm not too worried about the extra angle. Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 20, 2007 Share Posted December 20, 2007 Legacy brighton with origional springs + kyb outback struts on the left, 1998 stock outback on the right. Same rims and tire size on both of them. The older legacy's may be different. Here's the one me and konrad put together, we used outback struts but for the life of me I can't remember which springs we used. We had to take the springs off to swap the strut caps. I think we used the outback springs, but i'm not sure. Link to comment Share on other sites More sharing options...
MilesFox Posted January 19, 2008 Share Posted January 19, 2008 looking at this picture there appears to be more sharply of an angle with thelower control arms on the red ones. i put forester struts in my leganus, it seemed to bring the fron tup but the back doesnt seem any higher. but then again the rear suspension was shot and the springs are worn. i have LOTS of travel in the rear so i'm sure i can get another 3 inches of wheel clearance by using taller springs and spacers Link to comment Share on other sites More sharing options...
Gloyale Posted January 26, 2008 Share Posted January 26, 2008 I just installed Outback struts on a 91 Legacy. Lifted the car about 2inch, plus the height of bigger tires(205/75/15). I like it. The "lift" blocks would actually lower the crossmembers and diff resulting in less ground clearance(but more room in the wheel wells) And you WILL have to use the A arm mounts and Trailing arm mount from the Outback, as well as the crazy inverted Mustache bar for the snout of the diff. Not worth it. OB struts alone give you better off road clearance for less work. A couple notes: 1. Drive the roll pins out of the axles before unbolting the knuckles. Otherwise the DOJ can be hyperextended when you flop the knuckle outward. Make sure the axle is back on the stub, and properly aligned before reasembly. 2. You must use the original(or direct replacement) Legacy springs and tops for the rears. The bolt pattern and centering is different for OB. The springs also need the taper to clear the body, the wide OB springs won't fit. 3. Brake line are routed through a clip on the strut. My preffered method here is to CAREFULLY grind out a notch that the line can slide through. Grind the new strut the same way. Once you reinstall the little clip, they will hold just the same. Nissan struts use that excact deign from the factory. Or unbolt the lines from the calipers and get brake fluid everywhere and do a bleed when you're done. I guess if you needed to change all you're fluid anyhow:rolleyes: ......... Either way works. Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted January 30, 2008 Share Posted January 30, 2008 right now im running outback struts on my 90 legacy wagon and it gave me about 2 inches or so, im running 215/75/15 tires, they rub a smidge at full turn, but other than that its good.... hoping to use the outback springs soon... as its a 90, not a 95+ it should do a little bit of good, maybe not much, but some.. and every little bit counts..... Link to comment Share on other sites More sharing options...
