Quidam Posted December 10, 2007 Share Posted December 10, 2007 Hey, Thinking of: Max compression ratio, hi lift, longer duration cams, max lift. Overlap? 110 degree centerlines? Don't know for sure. Gen 1 heads. No cracks. pocket port, multi angle valve job, by my most convenient racing engine builder. Titainum retainers. Looking to turn 9000 rpm. Custom intake, carbureted. Well that's a start. Link to comment Share on other sites More sharing options...
pheonix165 Posted December 10, 2007 Share Posted December 10, 2007 let me be the first to say...its just cheaper to do an ej swap...its been proven. but if you that in love with the engine. good luck Link to comment Share on other sites More sharing options...
archemitis Posted December 10, 2007 Share Posted December 10, 2007 titanium retainers dont have anything to do with high rpms, unless you have the heavy springs, and titanium valves to match. im pretty sure you belts would catch on fire at 9k. ej22 way easier and cheaper, for more hp than your talking about building. but 10.5 or 11:1 should be doable with the right cam and ignition advance. i forget the exact calculations, but a turbo motor is close to 12:1 runing compression at full boost. Link to comment Share on other sites More sharing options...
Quidam Posted December 10, 2007 Author Share Posted December 10, 2007 let me be the first to say...its just cheaper to do an ej swap...its been proven. but if you that in love with the engine. good luck Well, thanks! Link to comment Share on other sites More sharing options...
Quidam Posted December 10, 2007 Author Share Posted December 10, 2007 titanium retainers dont have anything to do with high rpms, unless you have the heavy springs, and titanium valves to match. im pretty sure you belts would catch on fire at 9k.ej22 way easier and cheaper, for more hp than your talking about building. but 10.5 or 11:1 should be doable with the right cam and ignition advance. i forget the exact calculations, but a turbo motor is close to 12:1 runing compression at full boost. Of course, the springs and seat pressure are a given. Good ones. No Tit. valves. 9K is doable. Belts will hold just fine. Doug Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 11, 2007 Share Posted December 11, 2007 Do it. I want to see this, it'll be inspiration to many if you can. EJ swapping is like throwing in the towel. Link to comment Share on other sites More sharing options...
subiemech85 Posted December 11, 2007 Share Posted December 11, 2007 just start using the E-85 I suggest starting with a 50% blend and working up BTDT!!! Link to comment Share on other sites More sharing options...
daeron Posted December 11, 2007 Share Posted December 11, 2007 LPG is out of the question? 115 octane makes for plenty of usable compression, probably more than you could configure without serious machine work on the pistons, and loss of "non-interference" status... I like the dual carb option, especially with LPG have fun, and keep us updated! Link to comment Share on other sites More sharing options...
