mcbrat Posted December 18, 2007 Share Posted December 18, 2007 what voltage does the ER27 MAF use? Link to comment Share on other sites More sharing options...
WJM Posted December 18, 2007 Author Share Posted December 18, 2007 what voltage does the ER27 MAF use? Good question. I dont know for sure...I would imagine it would take after the EA82 and use a 0-10v, but since its 1/2 pre-EJ technology and 1/2 EA technology...it could be a 0-5v. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted December 19, 2007 Share Posted December 19, 2007 er27 and ea82 share the same ECU PCB...so.. prolly the same maf as well..since so much else is the same.. Link to comment Share on other sites More sharing options...
ausubaru92 Posted December 19, 2007 Share Posted December 19, 2007 So if the EA82 and ER27 share the same MAF, that must mean that the when in the EA82, the MAF still has heaps of headroom. Has anyone ever measured the output voltage of the MAF when making power? For example, does it give 4.9 volts when the car is at factory boost at 5000 rpm? or is the voltage much lower? Link to comment Share on other sites More sharing options...
calebz Posted December 19, 2007 Share Posted December 19, 2007 For example, does it give 4.9 volts when the car is at factory boost at 5000 rpm? or is the voltage much lower? Given that its a 10V maf, and it is also the trigger for fuel cut, I am going to guess that at 5000 RPM, WOT, Full boost, it is probably getting pretty close to the 10V mark at that point I haven't measuered it, but the fact that it triggers fuel cut tells me that it is topping out its voltage. The more air (Bigger turbo and such), the more quickly it reaches that voltage. Link to comment Share on other sites More sharing options...
ausubaru92 Posted December 19, 2007 Share Posted December 19, 2007 Given that its a 10V maf Sorry, i meant 9.5v. But yeah you get my idea. Link to comment Share on other sites More sharing options...
calebz Posted December 19, 2007 Share Posted December 19, 2007 Sorry, i meant 9.5v. But yeah you get my idea. I think I am going to try to get in on the next Beta. I am curious to see what I can do with one of these, a decent FPR, fuel pump and possibly some larger injectors than the nissan ones I am using. I have a set of 450ccs around here somewhere.... Might use a 5th injector in conjunction with it, not sure on that yet though. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted December 19, 2007 Share Posted December 19, 2007 the problem is making the safc work with the 0-10v maf properly. ahh, so the safc needs 0-5v, and our MAF uses 9-10v? So basically, we just need a way to cut our voltage in half, run it through the safc, then double it again to the 0-10v to go to the ECU? If so, that's easy to do. I probably have enough stuff on hand to make something up real quick. -Dave Link to comment Share on other sites More sharing options...
beataru Posted December 20, 2007 Share Posted December 20, 2007 Make me one too, and while your at it, send me a SAFC for me too! Link to comment Share on other sites More sharing options...
joostvdw Posted December 21, 2007 Share Posted December 21, 2007 ahh, so the safc needs 0-5v, and our MAF uses 9-10v? So basically, we just need a way to cut our voltage in half, run it through the safc, then double it again to the 0-10v to go to the ECU? If so, that's easy to do. I probably have enough stuff on hand to make something up real quick. -Dave that's exactly what I was thinking a while ago, but nobody listened It shoudnt be too hard with a couple of quite simple electronics. Link to comment Share on other sites More sharing options...
calebz Posted December 21, 2007 Share Posted December 21, 2007 that's exactly what I was thinking a while ago, but nobody listened It shoudnt be too hard with a couple of quite simple electronics. True. But a new Apexi SAFC is $360 A used one STARTS above $100 generally. Then you have to deal with rigging it to work. The advantage of this homegrown solution is that it is under $100 and works with the correct voltage range right out of the box. Link to comment Share on other sites More sharing options...
WJM Posted December 22, 2007 Author Share Posted December 22, 2007 The advantage of this homegrown solution is that it is under $100 and works with the correct voltage range right out of the box. You mean...right off the table once the soldering is fixed. Link to comment Share on other sites More sharing options...
