DerFahrer Posted December 14, 2003 Share Posted December 14, 2003 I had been chasing a gritty feeling in my clutch pedal for some time now, I figured it was just a bad cable, even though it was recently replaced... Well, it developed into a very irritating noise last night, and I had a friend depress the pedal while I watched the fork. It is wobbling inside the bellhousing!!! :madder: So now I get to do my first transmission drop and reattach the lever securely to the TOB... I theorize that is shook loose because: The clutch was replaced in the summer of 02, when all the clutch shudder TSB's were going around :temper: ... I can easily get the new clutch to shudder, so I believe it's a new OEM clutch. I'm guessing the few times I accidentally made it shudder probably wiggled the fork loose... So now I get to beg my family for Christmas money early, so I can get the XT operable again, so I can put the Leg back in the garage... :boohoo: Link to comment Share on other sites More sharing options...
alias20035 Posted December 14, 2003 Share Posted December 14, 2003 Originally posted by subyluvr2212 I had been chasing a gritty feeling in my clutch pedal for some time now, I figured it was just a bad cable, even though it was recently replaced... Well, it developed into a very irritating noise last night, and I had a friend depress the pedal while I watched the fork. It is wobbling inside the bellhousing!!! :madder: So now I get to do my first transmission drop and reattach the lever securely to the TOB... I theorize that is shook loose because: The clutch was replaced in the summer of 02, when all the clutch shudder TSB's were going around :temper: ... I can easily get the new clutch to shudder, so I believe it's a new OEM clutch. I'm guessing the few times I accidentally made it shudder probably wiggled the fork loose... So now I get to beg my family for Christmas money early, so I can get the XT operable again, so I can put the Leg back in the garage... :boohoo: Heres an issue: If you installed one of the clutch assemblies that was recalled as original equipment will Subaru replace it for free? I feel they should since it is a defective part. The recently updated clutch assemblies (after May/June 2003) still judder, but not nearly as often. Link to comment Share on other sites More sharing options...
DerFahrer Posted December 15, 2003 Author Share Posted December 15, 2003 It was not installed by Subaru, and I'm not 100% sure it even IS an OEM clutch. But with the way it shudders, it very well could be. Nevertheless, since a shadetree mechanic did the work (and very sloppily I might add ) I don't think they'll honor anything... Link to comment Share on other sites More sharing options...
