dominical1 Posted December 11, 2007 Share Posted December 11, 2007 Hi, Does anyone have any tips on a product or homemade solution that would remove antifreeze film from an interior windshield? My son's hatch heater core sprang a leak and fogged it up pretty well and left a nasty residue behind. Anyone had any experience with this? Windex is basically useless and an ammonia/water solution didn't seem to make any difference. Thanks Link to comment Share on other sites More sharing options...
Caboobaroo Posted December 11, 2007 Share Posted December 11, 2007 get the non ammonia based window cleaner. It'll be in a pressurized can like spray paint and will spray out foam instead of liquid. Should get the nasty residue off the window. Link to comment Share on other sites More sharing options...
dhise Posted December 11, 2007 Share Posted December 11, 2007 If you have any oven cleaner handy you can see if that will work as well. I know it'll take off some nasty stuff on home windows but not too sure about antifreeze... -Doug Link to comment Share on other sites More sharing options...
davebugs Posted December 12, 2007 Share Posted December 12, 2007 Drygas (Isapropyl alchohol) has a lot of weird uses. Never tried it for this but if you have any around it may be worth it. It's excellent to clean wipers, paint before double faced body tape, etc. Link to comment Share on other sites More sharing options...
chef_tim Posted December 12, 2007 Share Posted December 12, 2007 Dawn dish washing soap and warm water, followed by windex to get rid of the soap film. Tim Link to comment Share on other sites More sharing options...
bheinen74 Posted December 12, 2007 Share Posted December 12, 2007 maybe 409 and lots of old t shirts for rags. Link to comment Share on other sites More sharing options...
crazyhorse001 Posted December 12, 2007 Share Posted December 12, 2007 Any REALLY good degreaser, like Castrol Super Clean, Simple Green, or Purple Power, should get it clean. Short of that....Coca Cola:eek: will do it too. Link to comment Share on other sites More sharing options...
cobcob Posted December 12, 2007 Share Posted December 12, 2007 Gasoline and a match? Isopropyl will most likely do it... watch out with any degreasers you use, they will probably stain the dash if they drip on it Link to comment Share on other sites More sharing options...
crazyhorse001 Posted December 12, 2007 Share Posted December 12, 2007 cobcob said: watch out with any degreasers you use, they will probably stain the dash if they drip on it Really? I used Castrol Super Clean on my dash in my Pinto, with out any ill effects. Of course, if the dash is spray dyed, or the degreaser is allowed to sit there, it'll bleach it. When you get the antifreeze off the glass, there'll be nasty sreaks of degreaser left behind, that Windex will take off. Just use the windex on the dash afterward to be sure no degreaser is left behind. Link to comment Share on other sites More sharing options...
