Bratbros Posted December 12, 2007 Share Posted December 12, 2007 Hi there, I have an '82 Brat and am working on changing the clutch because it was slipping. I pulled it apart and found the disc to have very little wear. It looks like the last person to change the clutch only surfaced the flywheel where the clutch disc wore, and not where the pressure plate attached. Does anybody know how deep the step is supposed to be on the flywheel? Also, does anyone have a safari bar to fit the Gen 2s? Thanks, Simon Link to comment Share on other sites More sharing options...
edrach Posted December 12, 2007 Share Posted December 12, 2007 Hi there, I have an '82 Brat and am working on changing the clutch because it was slipping. I pulled it apart and found the disc to have very little wear. It looks like the last person to change the clutch only surfaced the flywheel where the clutch disc wore, and not where the pressure plate attached. Does anybody know how deep the step is supposed to be on the flywheel? Also, does anyone have a safari bar to fit the Gen 2s? Thanks, Simon Check with your local independent Subaru shop and ask them what machine shop they use for flywheels; they should know. Link to comment Share on other sites More sharing options...
ivantruckman Posted December 12, 2007 Share Posted December 12, 2007 if you have the flywheel machined you have to have a thicker clutch disk or pressure plate to compensate fot the amount of meterial taken off by the machening, they usally come in sets Link to comment Share on other sites More sharing options...
Skip Posted December 12, 2007 Share Posted December 12, 2007 sorry Ivan, I do not believe this is what Bratbros has in mind. The flywheel on these engines have a "step" between the pressure plate mounting surface and the clutch disc surface. When a flywheel is "surfaced" both surfaces must be turned the same amount, thus maintaining the proper "step". Look closely at the following picture you will see this step on the rusty flywheel I am about to turn. Unfortunately I do not have the EA81 specs but can provide EA82 specs. I am not positive they are the same thus I will not speculate. I am sorry I can not provide the answer I just wanted to clarify the question. Link to comment Share on other sites More sharing options...
