biffanyus Posted December 14, 2003 Share Posted December 14, 2003 After putting in a new(used) gas tank on my 82 Brat, I can only fill it very, very slow or it overflows. I think it gets filled up in the hose that runs from the hole to the tank. Its the same hose that was there before the new tank and it filled up fine. Its been like this awhile and now that its f#@$ing cold outside its a little anoying that it takes me 5 min to put $10.00 worth of gas in. Anyone else have this promblem? What can be done? Link to comment Share on other sites More sharing options...
Skip Posted December 14, 2003 Share Posted December 14, 2003 Biff two things to check 1) the large dia fill hose got kinked somehow when installing the tank 2) or the smaller dia. top "tank vent" hose that connects to the steel portion of the fill hose system, it maybe kinked. This hose lets air out of the tank as gas goes in and allows it to "vent" through the steel connection portion. This will cause gas to back up and trip the nozzle. Hope this helps solve the riddle Link to comment Share on other sites More sharing options...
northguy Posted December 14, 2003 Share Posted December 14, 2003 My money is on problem #1. Link to comment Share on other sites More sharing options...
83projectbrat Posted December 15, 2003 Share Posted December 15, 2003 funny thing is my 83 is the SAME thing, its so annoying i HATTTTEE it. mcbrat told me the flipper thing in the filler tube could be stuck. this prevents gas from going out if the car is tipped over ? im gonna check it out. but does yours gurgel then when the gas goes down Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2003 Share Posted December 15, 2003 Yeah - the large hose is easy to kink, and if you don't get it ALL the way on the tank tube, it will have too sharp of a bend in it. It takes some real muscle to get the tube all the way on - done it several times when replacing / moving tanks. The flapper thing in the fill tube can be seen, and operated with your finger - it's right near the opening, and if you can insert the nozzle all the way, then it's working..... GD Link to comment Share on other sites More sharing options...
TomRhere Posted December 15, 2003 Share Posted December 15, 2003 And I've seen it happen more than once. There's some tape over the tubes on the replacement tank, and you didn't take it off. Just a thought. Link to comment Share on other sites More sharing options...
