murphsubaru Posted December 17, 2007 Share Posted December 17, 2007 My 99 Forester's ABS hadn't worked for about a year untill yesterday. It started working after I pulled the fuse and put the fuse back in. Today ABS is not working again. The abs light is not on. Any thoughts? Link to comment Share on other sites More sharing options...
nipper Posted December 17, 2007 Share Posted December 17, 2007 A bad relay ? Does the ABS light work? How can you tell its not working? nipper Link to comment Share on other sites More sharing options...
OB99W Posted December 17, 2007 Share Posted December 17, 2007 A bad relay ? Does the ABS light work? How can you tell its not working?Indeed, does the ABS light come on at all? I refer back to:http://www.ultimatesubaru.org/forum/showthread.php?t=75545&page=2 Link to comment Share on other sites More sharing options...
murphsubaru Posted December 17, 2007 Author Share Posted December 17, 2007 Indeed, does the ABS light come on at all? I refer back to:http://www.ultimatesubaru.org/forum/showthread.php?t=75545&page=2 NO, never has. Link to comment Share on other sites More sharing options...
nipper Posted December 17, 2007 Share Posted December 17, 2007 NO, never has. Well start there, that bulb is burned out. nipper Link to comment Share on other sites More sharing options...
OB99W Posted December 17, 2007 Share Posted December 17, 2007 NO, never has.You need to find out why, and take care of it. Once the bulb is working, it should be possible to retrieve trouble codes that can help with further diagnosis. Link to comment Share on other sites More sharing options...
