unibrook Posted December 17, 2007 Share Posted December 17, 2007 Hi, On my 2001 Forester, I found the black ABS connector above the brake pedal, I stuck the nearby black ground wire into the lower right hole, and I have read out the codes. What I need now is a website that describes what each code means. Does anyone know of a website I can go to to find this out? I believe my codes were: 23, 24, 27. Thx for any help. And thx to Porcupine for telling me how to get the codes using the connector. Link to comment Share on other sites More sharing options...
OB99W Posted December 17, 2007 Share Posted December 17, 2007 [...]What I need now is a website that describes what each code means. Does anyone know of a website I can go to to find this out? I believe my codes were: 23, 24, 27. [...]For the codes you mentioned, see attached. I'd suggest checking the resistance of those wheel sensors; they're typically around 1.2-1.3 kohms. Link to comment Share on other sites More sharing options...
unibrook Posted December 17, 2007 Author Share Posted December 17, 2007 Many thanks for the code chart. Is there a website that has all of the codes? Seems hard to find. Where did you get those codes? thx. Link to comment Share on other sites More sharing options...
OB99W Posted December 17, 2007 Share Posted December 17, 2007 You're welcome. Check your Private Messages. Link to comment Share on other sites More sharing options...
jverbarg Posted January 10, 2008 Share Posted January 10, 2008 How exactly do you "read" the codes? Would these also apply to my '96 OBW 2.2l 5sp once I know that? My ABS light is on as well and trying to figure out what to look at. Thanks, Josh Link to comment Share on other sites More sharing options...
OB99W Posted January 10, 2008 Share Posted January 10, 2008 There's lots of good info at The End Wrench site, http://endwrench.com/ . For ABS, in particular look at the archive of the August 2002 issue. These two articles from that issue should allow you to identify which system you have, and help find the self-diagnostic procedure: http://endwrench.com/images/pdfs/IdentifyInfo.pdf http://endwrench.com/images/pdfs/ABS.pdf 1 Link to comment Share on other sites More sharing options...
