oil leaking onto exhaust (or project rodent decapitator)
Tired of being engulfed in a cloud of smoke and awful smell at stoplights due to oil leaking onto my exhaust. A few inspections shows that it is coming from a million places (ok, all the common places and then a few more). I don't have the time at the moment to trouble shoot all the potential leak areas, so as a short term solution I installed a metal belly pan that catches the drips and keeps them off the exhaust.
The pan is a piece of 22 ga plated steel, cut to fit, wedged between the transmission and the "Y" ahead of the cat, then bolted to the frame with 1/4" bolts.
Here's a pic. It's amazing I didn't chop off any fingers on the sharp edges shoving that thing in there.
Well i can tell you that you are going to have to adress the leaks sooner then later. You have cam seals, main crank seal, and probably the oil pump needs resealing. That can all be done at the next timing belt change.
The way those leaks work, I dont think thats going to help. Good luck.
nipper
Infi, do you really feel this is the proper forum for this kind of porn? Really?
(Sorry. I couldn't resist)
Juan
You are correct. The leaks from the headgasket etc. are minor in comparison.
I had the same problem with my RX. Not quite that bad though. I replaced all of the rear seals when I put a new clutch in at 220k miles. It's at 322k now and all is still well. It took about 2 hours to pull the engine. Good times!:headbang:
Still haven't driven it to check things, but....my wife drove it and didn't notice burning oil smell or smoke. Also, it no longer drips oil on the drive way. I think I've solved the problem (oil dripping on exhaust) until I can get the oil seals replaced.
