Mish Posted December 19, 2007 Share Posted December 19, 2007 Hello, I would like to convert my 1987 1800 Wagon to LPG and I was wondering can EA82 engines run on LPG without problems ? Are there some general tips on what to do before conversion ? Link to comment Share on other sites More sharing options...
monstaru Posted December 19, 2007 Share Posted December 19, 2007 read quite a bit about timing.and learn your engine before you take this project on.ie,how it reacts under load and whatnot so that you can revel in the wonders of lpg. Link to comment Share on other sites More sharing options...
Mish Posted December 20, 2007 Author Share Posted December 20, 2007 read quite a bit about timing.and learn your engine before you take this project on.ie,how it reacts under load and whatnot so that you can revel in the wonders of lpg. Do I need to change spark plugs, i.e. would they behave better with LPG if I go with hotter or colder range ? I plan on using BPR6EY-11, but do not know how will that affect driving on LPG. Link to comment Share on other sites More sharing options...
hyrysc Posted December 20, 2007 Share Posted December 20, 2007 Gotpropane.com has a wealth of info on this type of conversion. Carbed is easier to convert than FI. Propane has a higher octane, so you can advance timing, but lower BTU so not as much power (but since we drive carbed GL's, we have power to spare LOL) Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 20, 2007 Share Posted December 20, 2007 Do I need to change spark plugs, i.e. would they behave better with LPG if I go with hotter or colder range ? I plan on using BPR6EY-11, but do not know how will that affect driving on LPG. you need plugs one grade colder.....and LPG is the one application that the uber-expensive "hi-performance" sparkplugs(i.e Platnums,super 4', splitfires etc) will give you better ignition than a standard plug.....i have Bosch Super 4 plugs in my LPG EJ18.....the difference in how much more smooth the starting, idle & running is on the Bosch's compared to NGK's is unbelieveable.... it was always a fight to get the motor to start on the NGK's...with the Boschs in i only have to wave my hand at the key and the motor's running Link to comment Share on other sites More sharing options...
Ginger48 Posted December 21, 2007 Share Posted December 21, 2007 The most important change you need to make when using LPG or CNG (compressed natural gas) is regapping your spark plugs to 0.025" due to the fact that they are dry gasses. This is very necessary for easier starting. You will experience a slight loss of power when using these fuels unless you install high compression pistons. These fuels run GREAT with compression ratios up to 14:1. Engine oil stays clean much longer too. Link to comment Share on other sites More sharing options...
Gloyale Posted December 21, 2007 Share Posted December 21, 2007 You will experience a slight loss of power when using these fuels unless you install high compression pistons. These fuels run GREAT with compression ratios up to 14:1. What about turbo charging? Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 21, 2007 Share Posted December 21, 2007 What about turbo charging? compression is compression....doesn't matter how you get there! same rules apply to an LPG system (ventury type) as a petrol carburetor..... carb must be sealed and you LPG regulator must have a boost reference port Link to comment Share on other sites More sharing options...
daeron Posted December 22, 2007 Share Posted December 22, 2007 it was always a fight to get the motor to start on the NGK's...with the Boschs in i only have to wave my hand at the key and the motor's running ...But, in a gasoline powered engine, would you still run NGKs???? You know my opinions on LPG.. to me, your word (regarding LPG) is Law. To me, NGK plugs are also Law. Left hand tells me the Right is wrong here.. I just want to make sure that you love the NGKs for normal applications before I accept this tidbit as Truth. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 22, 2007 Share Posted December 22, 2007 ...But, in a gasoline powered engine, would you still run NGKs???? on a petrol fueled engine i would definately run NGK's....no point paying for uber-expensive kit when you don't need it i don't know why the NGK's wouldn't do the job in the new motor, i've never had a problem with them before....all i know is that on a brand new set of NGK's it ran like a 'sack'.....bosch's in it an it runs like clockwork Link to comment Share on other sites More sharing options...
daeron Posted December 22, 2007 Share Posted December 22, 2007 on a petrol fueled engine i would definately run NGK's....no point paying for uber-expensive kit when you don't need it Excellent.. I just needed that bit of info to confirm that you and I were of like mind regarding NGK spark plugs. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 23, 2007 Share Posted December 23, 2007 no point paying for uber-expensive kit that makes me sound like a cheapskate:eek:.....oh bugger...cats outa the bag now:lol: Link to comment Share on other sites More sharing options...
daeron Posted December 23, 2007 Share Posted December 23, 2007 that makes me sound like a cheapskate:eek:.....oh bugger...cats outa the bag now:lol: A Subaru-er??? Cheapskate? Surely you Jest! Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted December 24, 2007 Share Posted December 24, 2007 A Subaru-er??? Cheapskate? Surely you Jest! lmao.....i'm sure those words arn't ment to be in the same sentence Link to comment Share on other sites More sharing options...
dave4christ Posted June 13, 2008 Share Posted June 13, 2008 Anyone have info on converting a '95 1.8 engine to compressed natural gas? Websites to check out, cost of conversion, tips if I wanna do it myself, legal issues, etc. I live in Washington State Link to comment Share on other sites More sharing options...
TeamCF Posted June 13, 2008 Share Posted June 13, 2008 Always kinda wondered about how this would work on a GL. Some of the guys I wheel with have "Dual Fuel" setups on thier Jeeps. They can switch between gasoline or propane with a switch on the dash. Pretty neat setup. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted June 14, 2008 Share Posted June 14, 2008 Anyone have info on converting a '95 1.8 engine to compressed natural gas? Websites to check out, cost of conversion, tips if I wanna do it myself, legal issues, etc. I live in Washington State i am running a ej18 on LPG....but with a distributor & homemade gaseous carburetor.... if you where going to convert a FI motor you would need a set of emulators to shut off the fuel injectors while running on gas. i don't know too much about CNG except that its even higher octane than LPG so your timeing could be advanced even further.....i have my ej18 running 20deg BTDC. One thing about gas fuels that isn't mentioned on most pages that have info is the fact that the fueling needs to tuned backwards to what petrol is...I.E...if you motor is pinging/detonating/knocking you need to lean-out the mixture when running LPG/CNG Link to comment Share on other sites More sharing options...
