Mancomb Posted December 22, 2007 Share Posted December 22, 2007 I have a 99 legacy outback wagon and 1 working remote. I bought a couple more on Ebay and have been trying to enter programming mode per that website everyone recommends. I have the alpine style remotes. Have tried unlocking doors, closing door, while holding brake turn key on (10 times aprox) until horn honks. Problem is that the horn never honks. Anybody know any tricks or have any tips? -Mancomb Link to comment Share on other sites More sharing options...
porcupine73 Posted December 22, 2007 Share Posted December 22, 2007 Are you turning the key from off to run (going past just the 'acc' position)? http://www.cars101.com has a pretty good write up on the procedure for all soobs. Link to comment Share on other sites More sharing options...
Skip Posted December 22, 2007 Share Posted December 22, 2007 here is the link in a bit more detail Subaru keyless entry Same on as Porc's but gets to the page with all systems Check the Alpine page and make sure your remotes match the pictures. There is a write up that sounds like what you are doing. Says it may need more than 10 on/offs. Link to comment Share on other sites More sharing options...
Mancomb Posted December 22, 2007 Author Share Posted December 22, 2007 That was the website I was looking at, I think I have tried as many as 14 key cycles in 15 seconds. The one remote that came with the vehicle and works is the alpine style according to the pictures. The remotes I bought are also alpine style, but that does not matter since I can't seem to get into programming mode. I have also tried as some have suggested in other threads on USMB to disconnect and reconnect the battery before starting the procedure. Here is what I have been trying: 1. Unlock all doors with remote 2. Open drivers and get in vehicle 3. Close door and hold brake pedal down 4. Cycle key from off position to on position as fast as possible listening for honk 5. Nothing happens? I am pretty sure all my doors are fully closed because the dome light is not staying on and the warning indicator on the I/C does not show any door open. How should I unlock the doors? I've tried the remote and pushing the button inside to open all the doors. Should I use the key and just unlock the drivers door? I'm thinking I might have to end up at the dealership, which I hate to do because I'm a Ford tech and dislike paying people to do what I do for a living. Any ideas are much appreciated Link to comment Share on other sites More sharing options...
Skip Posted December 22, 2007 Share Posted December 22, 2007 By chance have you looked under the dash for the keyless entry service button? Maybe it would help getting it into programing mode? My MY00 Imp had one I needed to use for programing. I'm sorry I can't remember which system it had. I do not think it was your system though. Link to comment Share on other sites More sharing options...
J A Blazer Posted December 24, 2007 Share Posted December 24, 2007 Do you have an alarm? I do, and discovered that an additional step was required in order to program the remotes I bought on eBay. Link to comment Share on other sites More sharing options...
porcupine73 Posted December 24, 2007 Share Posted December 24, 2007 When you cycle the key from off to on, how many clicks is that? Do the dash warning lights come on when you go to on? Link to comment Share on other sites More sharing options...
Mancomb Posted December 24, 2007 Author Share Posted December 24, 2007 When turning key from off to on I think I hear 2 clicks and the dash lights do come on. I don't think I have the alarm option. Link to comment Share on other sites More sharing options...
OB99W Posted December 24, 2007 Share Posted December 24, 2007 When turning key from off to on I think I hear 2 clicks and the dash lights do come on. I don't think I have the alarm option.This previous post of mine may help: http://www.ultimatesubaru.org/forum/showpost.php?p=390602 The key cycling has to be done carefully; if you're sloppy, the pulses aren't seen properly. Stop after the tenth cycle with the key in the LOCK position, but don't remove the key. That's when the horn should sound. If that isn't clear, when I get a chance I'll post verbatim what it says in the owner's manual (pages 1-13 to 1-16). By the way, there's no mention of the brake pedal in the procedure. Link to comment Share on other sites More sharing options...
mwatt Posted December 24, 2007 Share Posted December 24, 2007 When turning key from off to on I think I hear 2 clicks and the dash lights do come on. I don't think I have the alarm option. vehicles equipped with alarm option have a "security" indicator light, in a panel that says "security" on it's lower edge, in the dash just to the left of the fog lamp switch. Vehicles without alarm option have a blank "knock-out panel" in the dash to the left of the fog lamp switch. Link to comment Share on other sites More sharing options...
