Easy question: Which A/C compressor is this?
I though the hitachi was the factory installed setup and panasonic the dealer installed setup..factory being alt on the outside and dealer being compressor on the outside..
In that case he'd have the hitachi setup no?
now I'm unsure :-\ the above picture does look like the compressor outside or 'dealer installed' setup, what I thought was the Panasonic setup
Kaz
psyc, you have not described the problem
except that the AC doesn't work and the comp is bad.
The pulser is seen hanging in front of the comp pulley
in the factory installed units.
This sends pulses to the AC control unit,
without this pulse the
AC will not function.
I do not know how common this type of protection
circuit is, just wondering if your tech knows about it.
Just a thought, sorry if it's NA
(Not Applicable)
