Intercooling W/O Hood Scoop?
I've got an MKII Toyota MR2 IC that I intend to install on my EA81T Wagon (lifted). However, I would prefer to avoid adding a hood scoop because I think it will look strange on the wagon.
So, I'm seeking solutions to use an Air-to-Air IC w/o a hood scoop. Has anyone installed one w/o? Is there an alternate placement of the IC that might work? Thoughts & objections?
No fan. I did stack some washers between the bolts on the hood hinge. Both between the body and the hinge, and the hood and the hinge. It raised the hood alittle to help air flow.
Not sure how dramatic the difference is cause i never got to put a scoop on my RX, but im sure it could only help.
The Saab 900 mounted their IC in the fender originally. Thats an option i was knocking around, but I wanted the least amount of pipe as possible. Another reason I didnt do TMIC.
