Increase Idle on EA81 with ************achi Carb
I have EA81 (1984 GL 4x4 4spd wagon), with a ************achi Carb on it. It currently idles at the factory set of 700 rpm, but I want to increase this to about 1000k... mainly, because I sleep in the back sometimes when traveling, and need a little more rpm's to the alternator so I can run my inverter and the heat, as well as radiator fan at the same time.. at 1k rpm, no problem, but at 700, impossible.
How do I increase the idle? is there a screw, or do I need to shorten the cable somewhere? install a spacer?
THANKS!!!
/mike
Awesome Idea.. Thanks GD!!!
I would like to report that I followed his advice and installed a switch on my console with a 12+ wire that I ran to the engine bay and spliced it into my existing A/C idle up solenoid... I then adjusted the vacuum actuator on the carb to what rpm I want (1500).. it works AWESOME.. this is great to help the car warm up in the winter, and when I need the extra rpms for my electrical demands (idling alot, working, and running an inverter, I do a lot of paperwork in my car, waiting to start other jobs)..
You have always been a fountain of knowledge and full of great ideas!!
Thanks again!!!
/mike
  GeneralDisorder said:
Best way would be to get an AC idle-up solenoid, and a vacuum solenoid and wire it up to a switch on the dash. Adjust it to 1000, and then only turn it on when you need the idle that high.
No problem. Glad that worked out for you. I can understand how you would need higher RPM for running certain accesories - heck that's why that solenoid exists anyway, because the demand of the AC compressor requires more fuel. The alternator's all put out more Amp's the faster you spin them too.
I usually don't sleep with engine on. I have a little propane catalytic flameless heater i will run, ewith a crack in the window of course.not to worry, i do have a carbon monoxide alarm in the car active all the time,,yet to go off.
  Frank B said:
If I slept in my Hatch I'd be dead in 10 minutes from the oil smoke burning off the Y pipe !!!!
