subaruguru Posted December 30, 2007 Share Posted December 30, 2007 hey my gf has an89 coupe and it has the 3at well it leaks idk where from yet but im gonna change the filter and gaskit if that dosent work is there anywhere els that they can leak from ?? TIA Rob. Link to comment Share on other sites More sharing options...
misledxcracker Posted December 30, 2007 Share Posted December 30, 2007 Could be leaking from the governor cover... Can't think of much more than that, or the pan of course. Check the side of the trans where the governor is, and if there's leakage, you'll notice it. Otherwise, it's the pan. It's easy to keep it from leaking; Wish it were easy to keep it working well :-\ Link to comment Share on other sites More sharing options...
subaruguru Posted December 31, 2007 Author Share Posted December 31, 2007 now that you mention it it is all greasy(coverd in tranny fluid and slege) ill have to check it. Link to comment Share on other sites More sharing options...
heartless Posted December 31, 2007 Share Posted December 31, 2007 check the lines that run to the radiator as well...our 88 coupe had a loose line and leaked there... Link to comment Share on other sites More sharing options...
