subiemech85 Posted January 2, 2008 Share Posted January 2, 2008 gen2 body style wagon 4spd s/r 4wd top starter ea71 with serial # 30xxx built 11/79 looking for clutch that has more holding power to better withstand the loads of pulling a trailer, driving in mud, and going uphill without slipping the clutch the clutch in currently acts somewhat like a snowmobile clutch... when 2, 3, or 4, apply throttle, rpm shoots up, then mph will increase while going uphill or not being careful with throttle what are my options??? ceramic?? Link to comment Share on other sites More sharing options...
mcbrat Posted January 2, 2008 Share Posted January 2, 2008 gen2 body style wagon 4spd s/r 4wd top starter ea71 with serial # 30xxx built 11/79 looking for clutch that has more holding power to better withstand the loads of pulling a trailer, driving in mud, and going uphill without slipping the clutch the clutch in currently acts somewhat like a snowmobile clutch... when 2, 3, or 4, apply throttle, rpm shoots up, then mph will increase while going uphill or not being careful with throttle what are my options??? ceramic?? use stock clutch, but have the step on the flywheel reduced Link to comment Share on other sites More sharing options...
Zefy Posted January 2, 2008 Share Posted January 2, 2008 get in touch with eurodrive clutches... they custom build them to your specs including disc material, step, and pressure... i got my custom clutch from them without a core for under 300 to my door. depending on what you want the price will be different... Link to comment Share on other sites More sharing options...
